Thread: AX-10 RC-Solutions chassis
Old 01-17-2011, 09:19 PM   #21
Suck it up!
Duuuuuuuude's Avatar
Originally Posted by 505tj View Post
With these tires do you mount them with the little white dot out or in?
Doesn't really matter, some people run them one way, some run them the other.
Ideally you want them all going the same direction though.
Duuuuuuuude is offline   Reply With Quote
Old 01-17-2011, 09:31 PM   #22
Thanks.. I do have them going the same direction.
505tj is offline   Reply With Quote
Old 01-17-2011, 09:34 PM   #23
Suck it up!
No you don't, look at your tread pattern. One side is running one way, the other side is running the other way.
Old 01-17-2011, 09:38 PM   #24
Oh weird, I just put all the white dots inside and didn't take another look..
Old 01-17-2011, 10:14 PM   #25
Suck it up!
The dots are just identifiers for the compound, not for in/out.
Don't feel bad, just about everyone does it at least once.
Old 01-17-2011, 10:17 PM   #26
Tossin' Salad
However, they are always marked on the same side...so can easily be used as a direction monitor. If looking at the rig from the port side, you should see all white dots from all 4 tires, or none at all.
KC_JoNeS is offline   Reply With Quote
Old 01-17-2011, 10:20 PM   #27
Suck it up!
Yer tho thmart.
Old 01-17-2011, 10:21 PM   #28
sence i see this in the pic above why do u run your socks upside down and dose it matter if the lower links are on the in side or outside closer to the tire
rockn is offline   Reply With Quote
Old 01-17-2011, 10:27 PM   #29
Tossin' Salad
Running his "SHOCKS" upside down is to get his center of gravity lower, thus increasing overall stability.
For your shock placement you should at least try it. In some cases it is good to get the shocks inside and the links outside...but some rod ends will not allow it, and cause some clearance issues.
I run Vanquish Razors on my rig, and this really gets my lower links far apart...which combats torque twist.
http://www.vanquishproducts.com/vp-s...nt-razors.html
Old 01-18-2011, 03:47 AM   #30
I have tried the Rovers every direction and combo and feel they work the same either and any way.
fortysixandtwo is offline   Reply With Quote
Old 01-18-2011, 07:11 PM   #31
All fixed. Thanks for pointing that out to me!!
So I mentioned earlier about the height with it being 7" tall and 2-7/8" clearance. Does that seem about right?
Old 01-18-2011, 07:17 PM   #32
Tossin' Salad
Yeah, that height is about good...but the best way to find out is to run it, and tune as necessary.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
