12-28-2010, 04:39 PM | #1 |
Pebble Pounder Join Date: May 2005 Location: Long Island NY
| AX10 W/Tuber Chassis "Pro Line"
Sup guys, Trying to get back into the Crawler scene.. Its Winter here in NY and I cant play with my Baja's as much.. So here is the deal I have a brand new hardly used AX10 "RTR Version" and it has not seen that much use or trail time. I would like to make a Scale Crawler out of it, more for appearance then anything but if I can also make a decent crawler for playing around in the rock garden that that would be even sweeter.. So I have been looking around the forums, net and Crawler Stores.. I'd like to give the Pro Line Tube Chassis a try.. I like the look but here's my question.. Can I get a Lexan or Plastic Body to also fit over the Tube Chassis?? I tried to see if I could find some threads, posts or build threads but didnt have much luck.. Here's what I am looking at.. Pro Line Tube Chassis- http://www.amainhobbies.com/product_...em-Super-Combo Scale Bodies I would like to see if I can get them to work with the Pro Line Tuber Chassis.. 1- http://www.amainhobbies.com/product_...-CGR-Roll-Cage 2- http://www.tgndistributing.com/gelae...exan-body.html 3- http://www.tgndistributing.com/1-10-...exan-body.html 4- http://www.amainhobbies.com/product_...0-Crawler-Body 5- http://www.amainhobbies.com/product_...0-Crawler-Body 6- http://www.tgndistributing.com/chevy...body-cage.html Thanks for the help guys.. |
12-28-2010, 05:06 PM | #2 |
Whats up, I am on HBF also. I have not been very active on there in the last year since I got into crawling. The AX-10 is a great rig you'll love it. |
12-28-2010, 05:21 PM | #3 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
i have built 3 of the proline tubers for my sons and i ... they work very well not as good as a comp rig but better then a scaler. not sure about putting a body over them, i just run the panel kit for them
12-28-2010, 05:22 PM | #4 | |
By any chance would you have any pictures of your rigs with the Pro Line Tuber and those panels?? I forgot the kit came with the panels, those would work.. Thanks | |
12-28-2010, 05:24 PM | #5 |
i dont have a pic of mine with the panels on it but there are some in this thread Proline tuber system on an scx10? |
12-28-2010, 05:26 PM | #6 | |
Thanks man I did a search and have looked through a ton of scale build threads but didnt see anything.. Much appreciated | |
12-28-2010, 05:28 PM | #7 |
12-28-2010, 05:32 PM | #8 |
Thanks man! A few other things I found I like.. Ok if I scratch the Pro Line Tuber, will I need anything else to use one of the following set ups on the AX10 RTR I have?? Here's a link to the RTR AX10 I have http://www3.towerhobbies.com/cgi-bin...=LXTZW2A1&P=ML 1- http://www.tgndistributing.com/1973-...roll-cage.html 2- http://www.tgndistributing.com/ambus...body-cage.html 3- http://www.tgndistributing.com/chevy...body-cage.html What will I need to get that AX10 to look like this maybe just different colors? http://www.tgndistributing.com/1973-...roll-cage.html Thanks for the help guys ! |
12-28-2010, 05:37 PM | #9 |
nope they will go on just like the body that you have...only thing i would recommend is getting shorter shocks, 4 link plates (strc makes good ones cheap ) and aluminum or delrin links if you have not already done so...oh and change the tires as well the stockers dont hook up to well
12-28-2010, 05:59 PM | #10 | |
Ok I I feel real out of place or I guess you can call me a newb I'm coming over from 1/5 & Baja's and am pretty darn lost right now.. If you dont mind could you hook me up with links to all the parts you just listed? The AX10 RTR I have sitting here in front of me is completely stock.. Thanks DeweyCJ5 | |
12-28-2010, 06:43 PM | #11 |
ok i have found for the shocks the stock emaxx gray ones work very well and they are cheap http://cgi.ebay.com/NEW-16-8V-E-MAXX...#ht_944wt_1139 i use the losi white springs http://cgi.ebay.com/Losi-XXX-2-75-Wh...#ht_2845wt_905 strc 4 link plates http://cgi.ebay.com/STRC-STA30485G-A...#ht_3365wt_905 http://cgi.ebay.com/STRC-STA30486G-4...#ht_3323wt_905 and links http://cgi.ebay.com/Axial-AX10-Scorp...#ht_2849wt_905 |
12-28-2010, 06:45 PM | #12 |
i have set up a lot of axial trucks like this and they work very well... i was most always in the top 10 of the club outings
