Thread: Anyone built a custom BTA setup?
Old 12-28-2010, 10:33 PM   #1
Question Anyone built a custom BTA setup?
It looks like the HR setup I got probably won't work, and CKRC says theirs won't work w/4-link configs. So, I'm considering other options. Axial's setup looks a lot like HR's, so that probably won't work.
I think I remember seeing one where the servo still faced forward, and one knuckle had a second arm which went forward to attach to the steering tie rod. Does this one ring a bell for anyone? I think this should allow the use of my current servo/batt plate config'd for 4-link.
Any help would be greatly appreciated!
JustinThyme is offline   Reply With Quote
Old 12-28-2010, 10:38 PM   #2
LD Racing makes the only BTA with a four link plate that I know of. The Axial setup with servo facing forward is for XR. What knuckles are you using? KC's bta link is sweet, but only works with Zero Acherman knuckles
Aggie01 is offline   Reply With Quote
Old 12-28-2010, 10:44 PM   #3
Ex Nor-CalRCRC slave
gunnar's Avatar
Egressor sells a dual arm setup for his excellent knuckles, among many other trick parts.
gunnar is offline   Reply With Quote
Old 12-28-2010, 10:47 PM   #4
Right now I'm using the CKRC BTA drag link with the 4-link plate from my Slingshot chassis. Was using it with a ST racing concepts 4 link plate.That with high clearance knuckles and it works great.
Wicked Klown is offline   Reply With Quote
Old 12-28-2010, 11:24 PM   #5
abadk9420's Avatar
X2 on the LD Racing BTA kit, it works great with VP high clearance knuckles and has you all set up to run a 4 link.
http://www.rpphobby.com/product_p/ldrste002.htm
abadk9420 is offline   Reply With Quote
Old 12-29-2010, 12:25 AM   #6
The Axial set-up is a direct bolt on... Just drill and counter sink two holes in the axle plate like a GC-3A for your 4 link mounting.
TOM
sourdojack is offline   Reply With Quote
Old 12-29-2010, 03:23 AM   #7
Anything for clod axels by chance?
sabohead is offline   Reply With Quote
Old 12-29-2010, 05:31 AM   #8
I'm using Venom alum, and not too pleased with them. I've got very limited steering. If I could get even just a good set of front facing hi-clearance knuckles for more complete turning travel, I'd be happy.
I'll check out some of the stuff you guy's mentioned. The LD Racing setup looks like my best option.
Thanks for the help. This one has been bugging me.
Old 12-29-2010, 02:46 PM   #9
Default bta
It was pretty easy to build one. Whene you set yours up with RickM, did you lower the battery / servo plate? If not, there should be plenty of room below it to make one with the axial high clearance knuckles and a KC_JoNeS link. I don't know if you looked at my thread lately, but I posted the pics you asked for....
Team Tactical Bacon is offline   Reply With Quote
Old 12-29-2010, 03:04 PM   #10
As the original designer of it... I can tell you it works great! Im still running the prototype.
Thundertechracing.com carries bta's for the clod
jetboat is offline   Reply With Quote
Old 12-29-2010, 06:55 PM   #11
Tossin' Salad
For the record, my link will not work with Axial High Clearance knuckles. My link is specifically for ZERO ACKERMANN knuckles.
Casey
KC_JoNeS is offline   Reply With Quote
Old 12-29-2010, 07:02 PM   #12
x3 on the LD Racing BTA. I had owned the CKRC kit before the LD kit. The LD kit was cheaper and had 4 link ready to mount. Not mention it's only $18 and has everything. Axial's kit is overpriced and so is CKRC's, compared to LD Racing.
Szczerba is offline   Reply With Quote
Old 12-29-2010, 08:26 PM   #13
Casey
Sorry for the bad intel. Thanks for correcting me.
Old 12-29-2010, 09:49 PM   #14
X4 Can't beat the price and it's set up for 4-link and all you have to do is change the rod ends on your existing 3-link links.
CmdrZod is offline   Reply With Quote
Old 12-29-2010, 10:59 PM   #15
The only problem I have with my LD Racing BTA is that it is designed for high steer knuckles, instead of zero ackerman. I will be switching to either VP zero ackerman or Felenfest knuckles. I just got some Super 300's and I want to make the most of them.
Old 12-30-2010, 08:30 AM   #16
It is NOT designed for high steer knuckles. It works well with them but not designed for them. It was designed for/around stock knuckles and any hopup knuckles that use the same dimensions.
Old 01-11-2011, 07:04 PM   #17
how is it supposed to pivot with it screwed right to the knuckles like that?
i cant get mine to work right, i am running the rc4wd aluminum knuckles but they arent high steer and the knuckles are visibly towed in bad with it bolted tight, do you have to have high steer to use this set up? i didnt get the vp only version but the standard version...? and would the 2 position knuckles affect things at all?
guapotaco is offline   Reply With Quote
Old 01-11-2011, 07:28 PM   #18
Try to Bend it
Highlucks's Avatar
I love my KC-JoNeS BTA. it works really well no binds what so ever.
My first BTA was just a piece of 8mm Delrin rod with a hump bent into the middle to clear tha axle pumpkin. That work OK with CKRC high steer knuckles. But nothing like my current set up.
Highlucks is offline   Reply With Quote
Old 01-11-2011, 07:58 PM   #19
Tossin' Salad
You just made me blush.
Old 01-11-2011, 09:38 PM   #20
Check out my sporty build... I have some detailed pics in ther of my bta. Custom plate by Duuuuuude, threaded rod tie rod with 2 small bends, an easy drag link with a revo and jato link with a short threaded rod (those longer screws with the head in the screw not like a standard screw... know what I mean... same thing you make links with) between them, and VP zero ackerman knuckles! I get full throw from a 300 axle so I know it works good! 50 degrees! The double sided one you were talking about is from felsenfest or egressor on here. Cool stuff! I run his locker! Super tight!
PipeDreams is offline   Reply With Quote
