01-05-2011, 02:55 PM | #1 |
Newbie Join Date: Oct 2010 Location: Russellville, Arkansas
| Eclipse with droop
Ok guys what are some different ways to setup shocks for droop. Such as what weight oils work best with ax10s. I have internal springs and it just don't flex well enough for me. I don't want to add a ton of weight to the wheels just to get it to flex on the rocks. I'm not sure what springs are in the shocks now as I just got the crawler used. Thanks a bunch.
01-05-2011, 04:38 PM | #2 | |
How much flex are you looking to get? 50-60* Should be more than suffice. Last edited by TSK; 01-05-2011 at 04:41 PM. | |
01-05-2011, 04:55 PM | #3 |
Have you run them without springs? 50-60* should be fine. The concept of droop is new to me. Its a learning process I guess.
01-05-2011, 05:21 PM | #4 |
Newbie Join Date: Nov 2010 Location: burlington
| droop
my sons eclipse came with droop setup. and i hate it. the sprung setup on my ax10 works better. i have tried all different weights of oil and internal spring rates on the droop setup. i am thinking about welding on new mounts to the chassis so can change it to sprung also.
01-05-2011, 05:33 PM | #5 | |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
01-05-2011, 06:31 PM | #6 |
I have never run droop without springs. In theory, you want a spring that is stiff enough to keep the chassis flat when on a steep sidehill or vert. When I pick up my truck, the suspension only drops about half way, but overall it get ss the 60ish degrees of total articulation. In most cases, a fully sprung setup seems to work better since it give more ultimate center ground clearance, but if you run a delrin skid, it;ll slide over everything with a droop setup. Tubers benefit most from droop because they inherently have a higher COG. |
01-05-2011, 08:31 PM | #7 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
I have been using TCS med. internal springs in my stock ax10 shocks as a droop with the stock 30wt oil in it and it works really well. I also run a "semi-droop" set up. Internal TCS shocks set up for droop and axial super soft springs on the out side normally. that gets me about 50-60 degrees of flex. Normal ride height. Compressed Extended I have tried it without springs or stoppers you get easily more than 90 degrees but there is sooo much torque twist its almost unusable. Last edited by DioptricStraw; 01-05-2011 at 08:38 PM. |
01-06-2011, 06:38 AM | #8 |
Rock Stacker Join Date: Jun 2010 Location: wnc
too much twist is a liability in some situations...there are more times than not when being able to carry a tire over a hole is better han letting the tire drop off into it... my newest set up is sprung with hpi super soft springs on tarxxas big bores on the front.. and axial shocks on the back limited internally to 3 inches of travel....its flexible enough to crawl over things, but still low enough to side hill really well... |
01-06-2011, 01:22 PM | #9 |
90* of articulation is way too much. that'll just get you into trouble. It lonly looks cool in poser shots.
01-06-2011, 04:20 PM | #10 |
Thats why i did it. Its at about 60 degrees now
01-08-2011, 02:45 PM | #11 |
Ok well the internal springs in my shocks are way to stiff then. When I pick it up off all four tires. It only drops like 1/2" and it has limiters on the outside about a 1/4"
