01-14-2011, 09:29 PM | #1 |
Newbie Join Date: Nov 2010 Location: bonne terre
| Low cg battery plate nimh battery
Hey guys. I need a new battery for my rig and I don't want to go lipo. I'm running a strc bta battery plate and I was wondering what the best cell count and mah size and config u guys have found that fits on the plate the best. Thanks guys
01-14-2011, 09:37 PM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i made a batt plate for the front of my crawler the tigress that held an 8 cell pack i also made .......bob .... |
01-15-2011, 04:43 PM | #3 |
Anybody else got any ideas? I'm running a bug body so it can't be that tall.
01-15-2011, 06:48 PM | #4 |
Newbie Join Date: Dec 2010 Location: Long Beach
you can do separate plates on the axle and run a split pack
01-15-2011, 09:47 PM | #5 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
I'm using a 7cell pack in the same place, but it lays flat and runs up over the upper links.
01-15-2011, 09:50 PM | #6 |
Newbie Join Date: Dec 2010 Location: Yucaipa, CA
01-16-2011, 07:51 AM | #7 |
What type of cells are u running in large cell counts? Sub c's or smaller? And will the axle battery plates work even though I'm running the lower cg plate.
01-16-2011, 02:42 PM | #8 |
Mine was a Traxxass 7 cell flat pack that I relocated the end battery to sit in the middle of the pack. I have my electronics on a link plate on the rear so the front is clear for the battery. Here is a pic of my truck before I relocated my electronics. |
01-16-2011, 06:41 PM | #9 |
Too much weight on the front end isn't bad? I want to go with something like a 3600 mah cell for run time but I think that may be to big. I have a 5 cell hump 5000 mah on the low cg plate now but it seems like everyone wants to run higher voltage packs for some reason
01-16-2011, 08:11 PM | #10 |
A higher voltage battery was a fraction the cost of a lower turn motor. Pumping more voltage into the stock 55t motor gives you more speed. I'm using a Sidewinder ESC which can handle a 3s lipo, so 8.4V NiMh is nothing for it. Not to mention, like you brought up, weight up on the front is a good thing, it helps your tires bite and not bounce. Once I do go Lipo, I'm going to have to add more wheel weight or something to make up the difference.
01-17-2011, 08:44 AM | #11 |
No idea what I'm doing Join Date: Oct 2008 Location: Underground, CO
