Meet the Mud Puppy Crawler (lots of pics) My AX10 was bought used and then built with whatever parts I could beg, borrow or trade for. If you are wondering why I used a particular part (eg: Integy upper links) it's probably just that it is what I had, could trade for, or buy cheap used. First thing I did when I got it home was swap the too long and too stiff stock springs for some Slash 4x4 springs I had kicking around. This made a semi-droop setup that seems to work fairly well. http://i659.photobucket.com/albums/u...othsprings.jpg I also ditched the stock body in favour of an HPI truggy body that I got free, just to look different. Next a set of Losi Comp-Claws I that got cheap with the truck went on, and it was ready for some fun. http://i659.photobucket.com/albums/u...er/posing2.jpg Flex was good but balance was top-heavy, and torque twist was ridiculous. First I helped the balance by putting Saddle Pack NiMh batteries on the front axle and relocating the ESC to the front upper 3-link. This improved crawling but made the torque twist even more apparent, so it was time to play with the suspension. An Xtreme racing carbon fiber side plate set, Axial Aluminum lower links and Integy upper triangular 3-link went on using Traxxas ball ends. The lower arms were covered with heat-shrink to help them slide, and Aluminum steering links went on at the same time. About this point the ESC and servo packed in, so a Traxxas ESC and cheap servo went in. http://i659.photobucket.com/albums/u...r/IMG_0163.jpg http://i659.photobucket.com/albums/u...r/IMG_0164.jpg Now I was getting some decent performance, but torque twist as still bugging me so I started getting really in-depth with the suspension. First I put a limiting strap on the front to keep it from unloading, and then I did this abomination and eliminated 85% of the twist. http://i659.photobucket.com/albums/u...r/IMG_0167.jpg http://i659.photobucket.com/albums/u...r/IMG_0165.jpg Christmas was around the corner, so I added an East End machine triangulated skid to the wish-list ( I had already butchered the stock one to inboard the links, but decided to try the real thing). This virtually eliminated the last of the twist, and now I can climb anything I can get traction on. http://i659.photobucket.com/albums/u...r/IMG_0166.jpg http://i659.photobucket.com/albums/u...r/IMG_0168.jpg http://i659.photobucket.com/albums/u...r/IMG_0181.jpg I have lost a slight bit of flex, but the performance is 50 times better overall. Next I decided I wanted to be able to run my bug body off my slash, so I got a proline vertical body mount kit. Unfortunately the holes did not come even close to the bug body hole locations, so I butchered the stock suspension links to use as extensions. http://i659.photobucket.com/albums/u...r/IMG_0179.jpg http://i659.photobucket.com/albums/u...r/IMG_0175.jpg http://i659.photobucket.com/albums/u...r/IMG_0172.jpg http://i659.photobucket.com/albums/u...r/IMG_0173.jpg And, last but not least, I also got a Comanche body for Christmas, so I decided to try to at least vaguely impersonate a scaler by picking up some used flat-irons and adding some spare parts from a broken New_Bright Jeep and one side of a cut up old Rock Lizard. http://i659.photobucket.com/albums/u...r/bodytrim.jpg http://i659.photobucket.com/albums/u...wler/pose1.jpg http://i659.photobucket.com/albums/u...wler/pose2.jpg I still need some rock rails, a fairlead, and a few other small details to finish it. Since the scaler parts all are attached to the body it only requires four screws to remove them and go back to comp trim. |
nice you should realy get a scale chassis"thumbsup" |
Good start! |
Of course if an SCX-10 comes up for sale for a steal of a deal I will be forced to buy it :roll: Instead I will keep (for now) with the all-pupose crawler and keep adding details to it. A licence plate for example http://i659.photobucket.com/albums/u...-10-35_992.jpg |
Neat that you turned it into a scaler! I always like reading budget threads. Lots of good ideas and unique solutions. |
real nice build you got there. Whats the budget up to now on it? |
Cash is only around $200, and that includes the new body and all new radio gear. :badger: Adding in value of trades - $310 Adding in value of parts I already had - $380 Woof. I never should add this stuff up. :shock: |
TCS X-Trail chassis is the way to go for a scale chassis but it looks fine just the way it is. Good Job! |
Cool build. I like the idea of keeping it on a budget. Props to ya man. |
