01-29-2011, 01:48 PM | #1 |
Newbie Join Date: Jan 2011 Location: iverness
| tcs chassis and shocks what to do?
hy i just put together a tcs edge chassis and my stock shocks dont work right i have soft springs out of diferent models rc that i own i just took the springs out and leave it with out them i put oil in the reat shocks #80 would it perform good like that o do i need to buy internal spring ? if so were can i buy then and would they fit my stock shock or do i need a new set up new to crawler thanks
01-29-2011, 07:08 PM | #2 |
First, use punctuation when you type. It makes it 1000% easier to read and understand what you're saying. Second, you need to explain what "don't work right" means. Since you mentioned springs a couple of times, I can only assume they are either too stiff or too soft. |
01-29-2011, 10:41 PM | #3 | |
Quarry Creeper Join Date: Mar 2010 Location: SF East Bay
Correct Usage: I am helping my Uncle Jack, off a horse. Incorrect: i am helping my uncle jack off a horse See what we mean? | |
01-30-2011, 12:34 AM | #4 |
Rock Stacker Join Date: Jan 2006 Location: Okinawa, Japan
I know the stock shocks are way to long for the eclipse chassis, would assume it is the same for the edge.
01-30-2011, 12:48 AM | #5 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
01-30-2011, 03:12 AM | #6 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
01-30-2011, 07:39 AM | #7 | |
Back on topic. Give us a picture or two of what your problem is. It sounds like you having binding issues... | |
01-30-2011, 06:06 PM | #8 |
O.K. All kidding and joking aside. I have actually owned and built this chassis with one of my AX10s. Using the stock shocks, you will need the TCS internal "droop" setup springs. You must run it in a "droop" configuration because the chassis was designed as a "droop" suspension to begin with. People have used a "droop" setup with the TCS Edge without internal springs, but you must use very heavy shock fluid, over 1000 wt., with the the 3-hole pistons. This presents other problems as well. Best advice, just put internal springs in the shocks. For a "sprung" setup, you will need to purchase shocks that are at a maximum, 80-90mm measured eye-to-eye. The trouble with this setup is that your C.O.G. is now slightly higher, which is not helped by the heavier, steel chassis. |
01-30-2011, 07:42 PM | #9 |
Like a boss... Join Date: Feb 2008 Location: NorCal
