02-02-2011, 06:20 PM | #1 |
Pebble Pounder Join Date: Aug 2010 Location: Australia
| Ax10 metal 70 tooth spur
Anybody know of a metal 70 tooth 48 pitch spur gear that will fit the ax10? Also any feedback on the vanquish ax10 alloy trans case? Are they worth the $. Thanks Martin |
02-02-2011, 06:33 PM | #2 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
Not sure about the VP alloy trans, but you can get a Golden Horizon Al tranny case for $13+S&H. |
02-02-2011, 08:29 PM | #3 | |
02-03-2011, 07:55 PM | #4 |
My question is why would you want to add weight to your rig when the stock case is much lighter? The problem with adding weight with a heavier tranny case is it sits high above your axle center line moving your center of gravity up when down is the best way to go. Personally I'd take a pass on the metal case. The gear is in the same logic I bet it's heavier than plastic. |
02-03-2011, 08:17 PM | #5 | |
02-03-2011, 08:26 PM | #6 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
The stock case is 1/2 ounce, the VP case is 1 oz. From what I've read, a 72 tooth spur is the minimum that will work with the Axial trans, unless your running a really big pinion. I don't know of any metal spurs that size.
02-03-2011, 09:23 PM | #7 |
I ran a 75 tooth spur at one time, had to do some grinding to use pinions in the 21-23t range, way to high gear for a crawler(I was new, and stupid enough to run CKRC "stage two", add in the extra size of a brushless motor and thats what it took for the motor to clear the upper link). I doubt a brushed motor could even pull that gear. I saw the light and changed chassis and went 12/93.
02-04-2011, 06:24 AM | #8 | |
Put that "fat ass" on a diet you just might like it. | |
