02-06-2011, 01:19 PM | #1 |
Newbie Join Date: Oct 2010 Location: Albuquerque
| "SNAP" went the front output....
Playing today and "SNAP" the front Tcase output gave up the goat.......Tcase gears were stock, but look at the center of the output and you will notice that it was hollow? What kind of sh$t is this? So it is now time for anouther set of gears, who's making the best set of Tcase gears? I'm not price shopping here I'll pay for what is good so that way I don't have to cut my wheelin trips short again. Looking at the plastic Tcase case that looks like the next thing to go when I upgrade the gears, should I upgrade that? who make the best case? again I'm not looking to price shop here either. Is there anything else in there I need to upgrade while I'm in there I don't want to go into that thing more than one time......Heath. |
02-06-2011, 01:36 PM | #2 |
Pebble Pounder Join Date: Jun 2010 Location: Farmington
Heres a set of steel outputs for $11. Might as well upgrade the case and gears while you have it torn apart. http://www.ckrccrawlers.com/ax30544-...on-p-2702.html |
02-06-2011, 01:37 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
RRP one piece output spool. |
02-06-2011, 01:45 PM | #4 | |
02-06-2011, 02:02 PM | #5 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
02-06-2011, 02:11 PM | #6 | |
Does VP have a case with built in dig? | |
02-06-2011, 02:21 PM | #7 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
HHMMMMMMMMM,,,,,,,,,,,,,,,,,, CREEPER TRANNYS DO'NT BREAK, NO BUT SERIOUSLY! |
02-06-2011, 03:20 PM | #8 |
If you don't have a dig yet, I'd go for the Vanquish dig since it comes with steel outputs. If you don't want a dig, check out the Robinson outdrive gear. The idler gear is another weak spot, so while you have it apart, drop in a Robinson idler too. Basically, make your spur the weak link in your transmission...keep it plastic. That way if something goes, it's easy to replace. If you go with a Vanquish case and Robinson internals, you should be pretty bulletproof. Good luck |
02-06-2011, 05:22 PM | #9 | |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
