02-07-2011, 02:13 AM | #1 |
Newbie Join Date: Dec 2008 Location: Augsburg
| Which AX Chassis to choose?
Hi! I would like to modernize my AX10. Which Chassis should I choose? BWD Wedge BWD SSS-R Gatekeeper GC3A Which one is your favorite? What advantages do the chassis have? Martin Last edited by ernie28ernie; 02-10-2011 at 03:09 AM. |
02-07-2011, 04:50 AM | #2 |
Rock Crawler Join Date: Jun 2009 Location: Middleburg
Gc3a hands down. It was designed by the 3 time champion and it flat out works. It also comes complete with everything you need including rod ends and is very easy to assmeble.
02-07-2011, 03:05 PM | #3 |
Quarry Creeper Join Date: Nov 2010 Location: Toronto Canada
Check this out, I was just in the same boat as you. I chose the GC3a which is on order and hopefully here soon. Help with new Chassis decision? |
02-07-2011, 07:44 PM | #4 |
Rock Stacker Join Date: Jan 2011 Location: santa clarita,CA
my gc-3a is awesome top notch quality |
02-07-2011, 10:03 PM | #5 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
GC3A all the way! The parts all work together for one awesome performer. Add underdrive/overdrive gears and you're set .
02-07-2011, 10:46 PM | #6 |
I have a sss-R so my opnion is biased. I think the orsion design is very outside the box and keeps the rig light. Perfect for a sportsman rig, and is very easy to setup with a BTA system. In my opinion, most sprung chassis (such as the wedge and gc3a) are pretty much just a matter of taste. They all can be setup to perform well, and when it comes down to it, the main diggerence is asthetics & space (for electronics and dig setups.) The only other real consideration that needs to be accounted for is the completeness of the chassis kit. Some come with uppers and lowers, some don't. Some come with hardware, some don't. I would suggest that you find some build threads on here, compare them, and choose what feels right. |
02-07-2011, 10:59 PM | #7 |
Rock Stacker Join Date: Oct 2010 Location: SLC
get a kit like the gc3a or the bender if you want some what limited set up time. if you go with any other (chassis only) you will need to make all your own links and figure out what works and what doesnt. my rc building attention span is 1-2 hours so i routinely get annoyed ha ha i probably have over 40 hours in tinkering. so kit if you want to run it and have it work out the box just a chassis if you like tinkering and trying to figure stuff out |
02-08-2011, 06:37 AM | #8 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
I run an swx droop and love it. It comes with links which makes it an easy install but you can always change them up later. I like it because it gives a good starting point to start tweaking and tuning.
02-08-2011, 08:14 AM | #9 | |
02-08-2011, 11:30 AM | #10 | ||
Hi! Thank you all for your replys! Quote:
The SWX is a good time on the market, maybe there are newer and better designs? Quote:
I've sent BWD an email and a pn but didn't receive an answer :( The Wedge with it taper design (low front, higher back) looks very fashionable, the GC3A seems a little more conventional. I would like a complete chassis-kit, albeit sooner or later some modifications will follow ;) But to dial in all the link-geometry with the only starting point of the chassis-sides is too much for me, for now... So I'm still a little biased with the favorite Gatekeeper! How much do you rate a taper design? The height of the Gatekeeper chassis-plates seems a little much, but maybe I'm just wrong? Looking forward for your replys ;) Martin | ||
02-08-2011, 11:33 AM | #11 | ||
02-08-2011, 09:39 PM | #12 |
the mayhem chassis are on sale too in the vendor section. only 35$ i think the mayhem chassis was my #2 choice. then you can get matching wheels |
02-09-2011, 12:05 AM | #13 |
Hi! Thank you all for your replys! Quote: Originally Posted by cagedcbr Check this out, I was just in the same boat as you. I chose the GC3a which is on order and hopefully here soon. Help with new Chassis decision? I've seen your thread, but although I have Mayhem wheelsand I am highly satisfied, the chassis is of no thought for me personally. The same vor the VP chassis. The SWX is a good time on the market, maybe there are newer and better designs? Quote: Originally Posted by TheSCorpionKing I have a sss-R so my opnion is biased. I think the orsion design is very outside the box and keeps the rig light. Perfect for a sportsman rig, and is very easy to setup with a BTA system. In my opinion, most sprung chassis (such as the wedge and gc3a) are pretty much just a matter of taste. They all can be setup to perform well, and when it comes down to it, the main diggerence is asthetics & space (for electronics and dig setups.) The only other real consideration that needs to be accounted for is the completeness of the chassis kit. Some come with uppers and lowers, some don't. Some come with hardware, some don't. I would suggest that you find some build threads on here, compare them, and choose what feels right. Well, I studied the SSS-R threads and liked the chassis more and more. It is a little eerie in looks, that point would fit me well I've sent BWD an email and a pn but didn't receive an answer :( The Wedge with it taper design (low front, higher back) looks very fashionable, the GC3A seems a little more conventional. I would like a complete chassis-kit, albeit sooner or later some modifications will follow ;) But to dial in all the link-geometry with the only starting point of the chassis-sides is too much for me, for now... So I'm still a little biased with the favorite Gatekeeper! How much do you rate a taper design? The height of the Gatekeeper chassis-plates seems a little much, but maybe I'm just wrong? Looking forward for your replys ;) Martin |
02-10-2011, 03:08 AM | #14 | ||
Hi! Sorry for my late reply, but I wasn't allowed to post anything... :( Thank you all for your replys! Quote:
I've seen your thread, but although I have Mayhem wheels and I am highly satisfied, the chassis is of no thought for me personally. The same vor the VP chassis. The SWX is a good time on the market, maybe there are newer and better designs? Quote:
Well, I studied the SSS-R threads and liked the chassis more and more. It is a little eerie in looks, that point would fit me well The Wedge with it taper design (low front, higher back) looks very fashionable, the GC3A seems a little more conventional. I would like a complete chassis-kit, albeit sooner or later some modifications will follow ;) But to dial in all the link-geometry with the only starting point of the chassis-sides is too much for me, for now... So I'm still a little biased, with being the Gatekeeper the favorite! How much do you rate a taper design? The height of the Gatekeeper chassis-plates seems a little much, but maybe I'm just wrong? Looking forward for your replys ;) Martin Last edited by ernie28ernie; 02-10-2011 at 03:39 AM. | ||
02-10-2011, 03:40 AM | #15 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
My favorite was not on the list. Not sure if they still make them but the UC FF4 chassis is awesome. I liked it so much it was carried over to my XR10 when I switched from the AX10 this winter. Wes |
02-10-2011, 07:46 AM | #16 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Gatekeeper designs GC3A for the win! The amount of setup info available for this chassis is unmatched and it's a proven winner in local as well as national level comps. |
02-10-2011, 09:58 AM | #17 | |
Rock Crawler Join Date: Apr 2010 Location: Central FL
Still, if you get a chance at one, go for it! | |
02-10-2011, 12:02 PM | #18 | |
Yours, Martin | |
02-10-2011, 12:54 PM | #19 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
You could buy a star and check out the classifieds,
02-10-2011, 01:12 PM | #20 | |
Glad I got mine when I did. Wes Quote:
