02-12-2011, 10:50 PM | #1 |
Newbie Join Date: Jan 2011 Location: West Point
| Droop shocks
Hey guys Im about to get an AX10 with a droop shock suspension setup I was just wondering what is a good setup for these. Does the drrop style work best or is there something yall would reccomend better?
02-13-2011, 03:08 PM | #2 |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
Tried it, didn't like it. Are you running 4" or 5" springs? I like to balance an internal spring behind the piston to the outer spring weight giving a) a bit of limiting (the amount of volume that the spring takes up) b) a lower ride height than standard and c) the articulation of the longer spring when needed. So, semi-droop for me. Depends on the chassis, the set up and how you prefer it. I also find that Losi golds on Losi 4" shocks work well without a "helper" but I still use av. light internal. I also like a rising rate spring and stronger internal balance spring on the the longer 5" shock but I've gravitated to 4" over time. |
02-14-2011, 07:46 PM | #3 |
Rock Stacker Join Date: Dec 2008 Location: CARO
droop is the why to go if your crawling trail riging u would want a normal set-uo |
02-15-2011, 05:26 PM | #4 |
Yeah this going to be a crawling rig. I havent gotten it yet so I dont know all the details just yet. Should know a little more this weekend Ill post up some more specs then. Thanks
