02-17-2011, 10:12 AM | #1 |
Rock Stacker Join Date: Jul 2008 Location: Carbondale
| bad gear mesh...?
i have had the 40/13 gears in the rear for a while, i just rebuilt with some aluminum lock outs and beefy axles, now have about 50% of the full rotation binding up, it turns but has a bad area that doesn't mesh properly, any ideas on what might need to happen? i already rebuilt it a couple times, maybe i got a bad set of gears? no movement on the pinion gear unlike the stock ones where it can move in and out a little bit, it will work but it's not smooth like all my other ones are
02-17-2011, 10:37 AM | #2 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Check the pinion depth again. You may have it to deep into the ring gear. This would create binding due to runout of ring gear. |
02-17-2011, 10:42 AM | #3 |
| like i said, the pinion doesnt move in or out like the stock gears do so no option on putting a washer or anything in there, really doesnt make since to me, i did just change the axles and a guy just posted about having a bent axle cause some problems, i dont see these beefy axles i put in being bent but i guess they could be, i got the ckrc lockouts that come with new axles and they are beef, the mesh wasnt perfect before either so i know it's not the axles
