02-16-2011, 04:56 PM | #1 |
Rock Stacker Join Date: Oct 2010 Location: San Antonio
| Axle gear ratio?
I was looking that they have 3 diffrent gear ratio's for the axle. 1=stock, 2=43/13, 3=36/14. What is the better combo, the 36/14 front and stock rear. Or stock front with 43/13 rear, or 36/14 front and 43/13 rear?
02-16-2011, 06:38 PM | #2 |
Rock Stacker Join Date: Jan 2011 Location: santa clarita,CA
36/14 front 43/13 rear |
02-17-2011, 11:08 AM | #3 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
i am using 36/14 front and stock rear. Seems to reverse without binding up. Tried the hi ratio in the front and the low in the rear. Seemed to bind and then unload when reversing
02-17-2011, 12:51 PM | #4 |
Quarry Creeper Join Date: Oct 2010 Location: Ukraine
Have front stock and UD rear. Work ok.. Get them both and figure out your own combo. This is the best way |
02-17-2011, 01:17 PM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: 801
HD fronts & 43/13 rear, works great
02-17-2011, 02:39 PM | #6 |
i have a question: Will under-drive rears, stock fronts make the front tires spin faster versus over drive front and stock rears? The reason i ask is that i do like the overdriven front tires. But i would like to keep the difference between the two axles at a minimum.
02-17-2011, 05:21 PM | #7 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
here's how they break down in ratios: UD: 43/13=3.307 OD: 36/14=2.571 Stock: 38/13= 2.923 The different is negligible in either direction IMO, as its 0.4:1 difference in reduction between all 3 gear sets. To answer your question, faster (more top end) gearing will come with OD from and stock rear. |
02-17-2011, 07:23 PM | #8 |
thank you wideload! Guess i will be putting stock back in the front and under drive in the rear
