02-19-2011, 10:51 AM | #1 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| C.I. - 4340 steel - Axial transmission outputs for Traxxas Maxx driveshafts
Crawler Innovations is proud to finally offer our 4340 steel - Axial transmission outputs for Traxxas Maxx driveshafts. This is a permanent fix to weak outputs, weak drive shafts, and heavy metal drive shafts. These outputs are cut from 4340 "Chrome Moly" steel. They are CNC machined to fit the Traxxas T / E Maxx drive shafts. The parts numbers are: Traxxas Heavy Duty input yokes #4928X Traxxas Heavy Duty drive shafts #4951X These are the axle drive shafts from Traxxas, not the smaller drive shafts for the transmission. The reason the front shaft is longer is to allow for clearance of larger spur gears in order to gear lower for increased torque. For brushless motors this is critical to ensure a smooth start up and no cogging. They are sold in a set. A set is one long front and one short rear. These are Made in the U.S.A. Vendor thread information is here: C.I. - 4340 steel - Axial transmission outputs for Traxxas Maxx driveshafts Here is a set installed on my SCX-10 based 1.9 scale Toyota. I am using a 96 tooth spur gear and 15 tooth pinion on a Tekin 13.5 sensored brushless inrunner motor using a Mamba Max Pro on 4S. The truck is as smooth on start up as my brushed 2.2 comp trucks using Holmes Hobbies hand wound motors. Yes, it's a giant 96T spur gear but the smooth crawlability even with a brushless motor is amazing. Here you can see just how much clearance you have between the output shaft, spur gear and drive shaft yoke. You could actually go bigger if you can find a company that makes a bigger 48pitch spur gear. This pictures shows that the drive shafts clear all link mounting and links. Crawler Innovation is in a growth phase at the moment. A new web site is under construction and the current web site will be deleted. I am not adding new products to the current web site, so you need to email me directly if you want these or other products not listed on the current web site. My direct email is: novasark@crawlerinnovations.com As always, thank you so much to everyone for your support of me and Crawler Innovations products. Without good customers like you, none of this would be possible. Thank you, Eddie |
02-19-2011, 08:21 PM | #2 |
Rock Stacker Join Date: Nov 2007 Location: Austin
Holy Hell those are clean! Excellent work Eddie. If these would of came out about 6 months ago, I would a bought a set for my spare rig, but its in pieces now... Great idea of putting them in a SCX too. |
02-19-2011, 08:40 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
Nice, I plan to turn my shafty to a sporty after I build a berg. These will be going in. I like my MIP shafts, but a whole lotta weight. These with T-Max shafts should lighten things up quite a bit.
02-20-2011, 08:46 PM | #4 |
I though Hell would freeze over before somebody made these again. Guess I'd better pack a jacket... |
02-22-2011, 08:18 PM | #5 |
RCC Addict Join Date: Dec 2005 Location: Tucson
any reason for chrome moly ? isnt there a less expensive steel i know its strong but not really needed.
02-23-2011, 08:19 AM | #6 | |
I'm actually extremely pleased with the final cost, because initially the machines shop was talking $75 per output! After the machine shop did this first run, the machine time and set up was less than estimated, so the cost went down considerably. I passed that savings on to the customer. Trust me, this is not a high mark up item. But it is the last pair of outputs you will buy in this style. | |
