3 link suspention help hey so i bought 2 sets of the high clearance suspention arms and they didnt come with those I-hole things that screw into the end of them. what are those called and aproximatly how much do they cost? thanks:mrgreen: |
ya i think thats what i need but like i also need a screw that goes inbetween both of them because those look like they are threaded and my links are threaded |
What you are looking for is a set screw, like these: http://www.rpphobby.com/product_p/axa186.htm but make sure they match the diameter of rod ends that you bought. |
Just wondering, why not use your old rod ends and set screws? |
these are exactly what i boughthttp://www.google.com/imgres?imgurl=...1t:429,r:8,s:0 and then if you look close enough you can seethat the stock set up is one peicehttp://www.google.com/imgres?imgurl=...1t:429,r:8,s:0 |
the second one didnt copy right http://www.google.com/imgres?imgurl=...20&tx=84&ty=53 |
I'm pretty sure that I used some M3 12mm ones when I did the same as you - RTC to bent lower links. Make sure that you use an M3 end though - some of the Traxxas ones are larger. |
You can get an all in one parts pack from Axial that has the threaded inserts (set screws) and rod ends, but the Traxxas ends are better. I bought the hardware kit with a color pack (all new links), I replaced the Axial rod ends 2 weeks later with the Traxxas. Here is the Axial kit with everything http://www.tcscrawlers.com/Axial-Rac...1-p-17066.html Here is just a pack of the set screws http://www.tcscrawlers.com/Axial-Rac...6-p-17047.html Here is the Traxxas rod end pack I used http://www.tcscrawlers.com/Traxxas-R...2-p-16324.html |
