07-08-2011, 09:03 AM | #21 | |
07-10-2011, 06:03 PM | #22 |
Quarry Creeper Join Date: Oct 2010 Location: SLc,UT
That rig looks pretty sick. That is a good way to go Ill have to hunt some down. thanks for that link. We had a comp this weekend and he spun the last piece of plastic in the transmission DOH! We got it fixed with another plastic but he needs run a an all metal geared trans. |
07-10-2011, 07:14 PM | #23 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| http://www.onlinemetals.com/merchant...d=30&top_cat=1 There's some and it's a great deal! |
07-10-2011, 07:34 PM | #24 |
07-11-2011, 07:58 AM | #25 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
Those tubes are nice. What size brass tubing is that? Or do you turn them down?
07-11-2011, 03:17 PM | #26 | |
It started as solid brass rod, dont know if they make tube with a thick enough wall to make it work. That would be nice if there was tube out there that works. Check this one there is more info on the pipes. East End Machine SNG Droop | |
07-17-2011, 01:55 PM | #27 |
I got some VP stuff for it. I dont know if it helps or not, kinda makes the rig feel top heavy. |
08-07-2011, 02:01 AM | #28 |
No one thought the vanquish asprin was funny? Got a new toy. Also I have a VP dig that is going in soon. It is set up so well right now that I wish I could install it with out changing the CG. It can honestly can pull off a line (ill work on a video clip) with no dig that so far 3 other rigs either cant get it or have to use dig. one is a shafty the other 2 are XRs. nothing ground breaking but that line always impresses the hell out of me. |
08-07-2011, 11:01 AM | #29 |
I get the joke now Wow a comm lathe! Nice job, should keep the motors running a good long time! Sounds like my rig, it's all in the setup and driving execution, not the DIG and weights! |
08-08-2011, 11:22 AM | #30 |
09-05-2011, 10:38 AM | #31 |
Got tired of breaking axles everytime out. The 16t HH crawlmaster has plenty of power to go around... going to install XR10 axles and some of KC jones LONGer beef toobs originally I cut and welded a XR shaft to see if I could do and I did and it worked out but the wider width is going to help out so I left the shafts alone. The toobs are nice right out of the box, all they need is holes drilled and tapped to secure them to the axle. They make this mod so easy. Fit up check... I have a set of berg offset mayhem wheels and some CW crawler wheels with adjustable offset if I want it narrower. Starting with stock AX10 offset wheels. more to come. |
09-05-2011, 12:52 PM | #32 |
I'm thinking of doing the longer beef tubes n my SSS-R. I need more servo/battery clearance. I'm concerned with the huge offset difference front to rear though. I typically run a narrower rear track, but eh... Can you post up some top down pics showing the track width difference while running the same wheels from to back? |
09-05-2011, 04:46 PM | #33 |
I can do that.. very soon too |
09-05-2011, 04:50 PM | #34 |
FYI, the toobs are 11mm wider each side wich is just short of a 1/2". with stock ax10 wheel offset that makes it about an inch wider. I thought it was going to be too wide and drag the diff a lot, but it worked out. Ill get some pictures up soon so you can see. Since you have Calvin's wheels you can make it whatever width you want too. |
09-05-2011, 05:52 PM | #35 |
I only have Calvin's wheel on my XR right now. I run some JunFac wideners on my SSS-R right now to get a little extra width.. Right now, my tires stuff the battery & servo due to the high clock ping I run. I figure going to the longer tubes will give me more clearance, and allow me to run the same size battery in both my rigs. But yeah, pics will help
09-05-2011, 08:24 PM | #36 |
here are a couple, more to come. |
09-05-2011, 08:25 PM | #37 |
miles of room for the tires to turn and not hit the shocks or links and room for whatever is on top of the axle. EDIT! I just saw there is no support under that servo/battery plate. ooops. He ran like that for a couple batteries too. Last edited by durrty; 09-05-2011 at 08:28 PM. |
09-05-2011, 09:13 PM | #38 |
After chatting to you, when I get the gear, I'm going to totally do this to my rig cheaper than s300 and God forbid anything goes wrong it's an easy fix I run my battery/servo tray without spacers and "yet" to have issues |
09-05-2011, 09:42 PM | #39 |
THat doesn't look too bad. I don't have spacers under my plate either, but the rx kinda supposrts the servo side. Which IMO is tha more imporatant side to support. |
09-06-2011, 12:43 AM | #40 |
zero ackerman would give me more!! home made steer arm. ended up not using the drag link this way. Just going through options. It fits perfect under the axle grind out the chub a little I bolted the housing together as much as I could before I drilled the toobs out. |
