03-08-2011, 01:58 PM | #1 |
Newbie Join Date: Feb 2011 Location: Woodland
| Stearing
Any tips or tricks to make the axial ax10 scorpion turn sharper?
03-08-2011, 02:26 PM | #2 |
Spend a few minutes searching and looking through the tips and tricks sticky thread and you'll have all of the answers you could ever want!
03-08-2011, 02:28 PM | #3 |
Yup. There's even a couple mods that you can do for free.
03-08-2011, 05:32 PM | #4 |
Super 300 axles, zero Akerman knuckles and a big strong servo there you go done deal. |
03-08-2011, 09:28 PM | #5 |
Rock Stacker Join Date: Aug 2008 Location: tamworth, nsw, australia
Changing the screws on the C's from button-head to counter-sunk heads will allow for the knuckle to travel a few more MM's; adding some toe-out helps a bit too. Both can be done with minimal tools with what should be readily available using stock components. More than that, you're starting to head down the path of better CV's (SUPER 300's etc etc) and zero-ackerman knuckles I believe, $$$
03-10-2011, 10:48 AM | #6 | |
Yes, I realize eliminating the servo saver is not the wisest idea. But at least I'm pretty good about not whining that blowing my servo "wasn't my fault". (Newbs; don't do as I do.) | |
03-10-2011, 10:56 AM | #7 | |
Rock Crawler Join Date: Apr 2010 Location: Central FL
I think you'll find that the servo saver is one of the first things to go on most comp ax10 builds. | |
03-11-2011, 06:19 PM | #8 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
03-11-2011, 07:02 PM | #9 |
Pebble Pounder Join Date: Nov 2010 Location: Texas where its too damn hot!
03-11-2011, 11:16 PM | #10 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
The answer is linked in my signature!
