03-18-2011, 12:50 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Scottsdale
| Motor Plate - Front Mounted Motor
I am looking for the motor plate that allows me to mount the motor to the trans on the opposite side of the spur gear from the transmission. I can't seem to find it. Thanks |
03-18-2011, 12:57 PM | #2 |
Pebble Pounder Join Date: Feb 2010 Location: Rapid City
GCM has them, not a direct fit for an SCX10 though.
03-18-2011, 01:03 PM | #3 |
Acutally, you can use the same motor plate. You just have to reassemble the transmission in hte opposite direction. It's modular in design |
03-18-2011, 02:10 PM | #4 |
| You are misreading what he is looking for I believe.
03-18-2011, 02:57 PM | #5 |
GSM relocated the intier motor. It doesn't move the motor to the opposite side of the spur gear. Reconfiguting the tranmission case doesn't change the position of the motor in relationship to the spur and transmission. I am looking for the motor plate that will allow me to have this setup: Motor, then Spur, then Tranmission. Basically the spur gear is sandwiched inbetween the Motor and Transmission. If that make sense? Last edited by bsn; 03-18-2011 at 03:09 PM. |
03-18-2011, 03:06 PM | #6 |
| My picture didn't work
Worthless post
03-18-2011, 04:07 PM | #7 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
I understand what your saying. What I have seen done before is using a 1/8" thick "stock style" motor plate, then you use spacers and longer screws to bolt on the motor. The one's I've seen haven't worked that well... TOM |
03-18-2011, 04:49 PM | #8 |
