03-24-2011, 11:09 AM | #1 |
Rock Stacker Join Date: Jan 2011 Location: Carencro
| What does your AX10 weigh? Please be specific if you can. What I mean is list your components so that we know what you are running. chassis,Wheels tires, shocks, springs, electronics what ever you want to list add it. If you know your sprung and un-sprung weights list them as well. The more info the better. I’ve seen that in a lot of the other sections (XR10, Berg, Bully, etc) they all have threads and discussions on what their cars weigh(RTR). Figured I’d try to start one in this section since I am getting ready to build an AX10 and weight will be a big concern for me. Not so much Overall weight as sprung v/s unsprung weight. With not much data to go off of on the AX10 I am not sure what a light AX10 is. If I learned anything in 1:1 crawling it’s that being light helps out a Ton. And if you have to be heavy (when crawling) do it in the axles! Last edited by SI10 LAN; 03-24-2011 at 11:11 AM. |
03-24-2011, 11:34 AM | #2 |
Quarry Creeper Join Date: Dec 2004 Location: Gardnerville
I've been lightening and messing with my rig recently. Spec list: - DNA SSS chassis with delrin links - Axial Axles aluminum C's & knuckles in front, Aluminum lockouts rear - CKRC wiggle servo for steering - Eritex Comp heavies in the front, Eritex Lighter weight in the back - Rovers with Nova foams - Axial trans with DNA Dig Hitec servo - Mamb Max with Integy 45t motor - JR receiver - Castle BEC - JC Concepts Rock steady single cab body I weighed it all last night and this is what I came up with. Chassis (Without tire's wheels) 3lbs 7.55 ounces Tire's & Wheels 2 Lbs 3.25 ounces Total - 5 lbs 10.80 Ounces. I started out shooting for under 5 pounds, and i'm at the point now where I need to swap out some parts in order to get there. First changes will be a lighter ESC and motor combo, smaller receiver and probably as a last resort type thing, ditch the DNA dig since I can honestly take it or leave it for normal use. |
03-24-2011, 11:45 AM | #3 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
6.5lbs rtr with 3s 850mah battery. FF4 steel gears, and beef tubes in the axle. sidewinder and bec. DNA dig w/ full size servo. Not sure how much weight in the tires. I need to take some out I know that. Mine is getting a rebuild with a new Fastback. |
03-24-2011, 12:20 PM | #4 |
Newbie Join Date: Aug 2010 Location: Lake County
| my ax-10
almost 5lbs dynamite front 4-link dynamite saddle pack plates custom rear 4-link stock shocks with tuned springs mounted outside integy aluminum c-hub and knuckles integy 129mm bent lower links strc trans plate stock wheels with lead sinker weights HB rover ex pink dots strc battery mount brace axial axles with 38/13 rear 36/14 front hitec HS-5955TG servo novak rooster crawler custom battery around the servo venom 2.4ghz custom electronics box on battery plate(travel soap container) |
03-24-2011, 01:59 PM | #5 |
Quarry Creeper Join Date: Oct 2010 Location: Ukraine
2250 grams w/o batteries on Fastback FXR turnigy 200 oz servo flysky receiver cc bec integy craapy rear shaft Axial BTA build thread Here is my story |
03-24-2011, 02:27 PM | #6 |
Quarry Creeper Join Date: Aug 2010 Location: Sheboygan
6.375LBs Slingshot CC Mamba Max Hitec HS-7955TG Spektrum rx CC bec M.I.P.Drive shafts Beef toobs Jones'N BTA VP Zero Ackermann knuckles HH 7t puller G-Force 1300mah 2s Double Phatties 15.25oz front wheel Delrin Double Phatties in rear |
03-24-2011, 08:03 PM | #7 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
fastback chassis stock tranny + vp hurtz dig (std sized servo) HH BRXL + HH 35T sporty motorbeef toobs, OD gears in front axle, stock rear axle hitec 7955 steering servo, custom BTA HH 1300 2s lipo MIP shafts 3/16" alum sleeve over 8-32 all thread uppers, 5/16" delrin sleeve over 8-32 all thread lowers delrin Mayhem 7's (+5oz each front, nothing rear) Weighs in right at 6 lbs +/- a few oz. Don't have an exact weight yet, but should soon. |
03-24-2011, 08:22 PM | #8 |
| 5.44 # RTR Axial Axles and Trans T1E Moonbuggy Chassis GC-2 Link Mounts Front/Rear VP Dig w/ Hitec 225 Servo Gunner Tubes Front Mamba Max 3.5" Big Bores JR 8711 Steering Servo FELSENFEST 0 Ackerman Knuckles w/ Weight System SLW VP Wheels Hater Tires Nova Foams |
03-24-2011, 09:08 PM | #9 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
My new Poison Dart Sportsman rig: 5.65 lbs (with 3S 1300 mAh battery) Holmes Hobbies BR-XL ESC Holmes Hobbies 45T handwound motor 18 tooth pinion 86 tooth HR spur gear Axial transmission HiTec HS-7954SH servo BEC at 7.0 volts Axial axles Front overdrive gears BEEF TOOBS front and rear Vanquish Zero Ackermann knuckles Axial aluminum Cs Axial aluminum rear lockouts 3Racing front CVDs with gunnar pins D_Lux knuckle weights Crawler Innovations Double Deuce 2 stage 5.5" foams at all 4 corners Hot Bodies Rovers (whites) Bad Attitude Machining wheels Poison Dart Chassis Frog Legs Traxxas Big Bore 3.5" shocks up front with longer Axial rod ends and Axial comp springs up front Losi comp shocks out back with short Axial rod ends and JeepinDoug spring cups Front VP 4 link plate rear STRC 4 link plate JoNeS'N BTA steering tie rod Spektrum SR300 RX Last edited by KC_JoNeS; 03-24-2011 at 09:47 PM. |
03-26-2011, 08:08 AM | #10 |
Croakin' across the pond! Join Date: Jan 2011 Location: Nottingham, UK
My Frogger "Boris" weighs 2590g all up. Wheelsets are 850g Front and 500g rear Chassis is 1240g Main parts of Spec. Frogger chassis Over/underdrive axles with HD lockers and 3racing cvd Hot Racing alloy knuckles and axles Stock Wheels, HB Rovers, weight as above 4 link uppers Novak Rooster and Rooster 55T, built-in BEC 17Kg servo Spektrum radio Losi 4" shocks, Gold springs, 40wt oil Mirrored transmission |
03-26-2011, 08:21 AM | #11 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
5 lbs 9.30 oz RTR total weight 2 lb 15.30 oz front axle weight 2 lb 6.40 oz rear axle weight CF slingshot chassis castle sidewinder ESC castle BEC hitec 7954SH servo tekin T35 motor overdrive front gears golden horizons C-Hubs golden horizons knuckles losi mini shocks losi grapler pro body MIP CVD's with gunnar pins MIP driveshafts spectrum SR3300T RX gunnar body mount 1000mah 3s lipo's stock Berg wheels pink dot rover's beef toobs in the front axle robinson racing solid outputs HR stainless steel idler gear |
