05-24-2011, 07:09 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: United States
| Mamba Max Pro Cheat Mode
Does anyone use this? I did a search on here and found very little. I have a 21.5 Tekin Redline on 4S so I have a lot of wheelspeed and good torque but im thinking of lowering my gearing more and maybe using cheat mode to get my wheel speed back up. Currently I have a 16t pinion and 93 t spur but thinking 10t 87t. What RPMs am I running this motor. Is it (KV X voltage = RPM)? so (2100X14.= 31080 RPM. So what I'm thinkin is over a certain rpm(prob within last 10%-20% of the throttle advance the timing somewhere between 20 and 50 degrees for hopping up on rocks and jumping gaps.
05-24-2011, 07:19 PM | #2 |
It use it on my LCC with MMP1C and it is NICE! |
05-24-2011, 07:36 PM | #3 |
How do you have it set up? Towards the end of the throttle? Degrees?
05-24-2011, 07:39 PM | #4 |
Yeah, IIRC it was 16,000 at 30*....however, the LCC is geared much lower than the Axial. Really, you will probably just have to play around with the setup and see what you like best. There are plenty of opinions on cheat mode for the LCC and I used those as a starting point, but still adjusted to fit my needs.
05-24-2011, 07:53 PM | #5 |
That makes sense....I'll have to put that on my to do list. Are you running the Tekin 21.5 as well? How hot does your motor get or do you have to monitor it at all?
