06-19-2011, 12:39 PM | #61 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
I would say shorter links. Where are the frog legz ?
06-19-2011, 01:24 PM | #62 |
Newbie Join Date: Apr 2011 Location: san jose
the frog legs were longer than the dlux ones I'm trying to get the most clearance also
06-19-2011, 01:26 PM | #63 |
Whats your wheelbase? edit: it looks like you're using long rod ends, thats probably your problem... |
06-19-2011, 02:46 PM | #64 |
I'm using losi link ends the same ones on the stock lcc upper links. I placed an order for new shafts so they'll b longer and I'm hoping that'll fix it. the lower links r dluxs ti bent links and the uppers r the lcc stock links. don't really wanna use different links as the dlux links r pricey and nice so not wantin to switch those. I had all this stuff working fine with the lcc chassis and I got the pd chassis and I'm determined to get it to work cuz the chassis is really nice
06-19-2011, 07:04 PM | #65 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
First off, what exactly are you trying to do? What trans and axle set is that? What wheelbase are you trying to get? Casey |
06-19-2011, 07:30 PM | #66 |
I'm just tryin to get it to work. the axle/trans is the stock lnc. the wheelbase I'm goin for isn't specific I'm just tryin to get this running
06-19-2011, 07:33 PM | #67 | |
JoNeS'N LCC Poison Dart build | |
06-19-2011, 09:16 PM | #68 |
ur links? the delrin ones that came with the chassis? those ones r the same length as the dlux ones I got plus I don't have ne rod ends that fit those set screws
06-19-2011, 09:51 PM | #69 |
06-19-2011, 11:52 PM | #70 |
will pick sum up tomorrow does nebody have a part number for the traxxas rod ends?
06-19-2011, 11:58 PM | #71 |
06-20-2011, 12:05 AM | #72 |
thanks for the help. I'll pick sum up tomorrow after work. once it's together I'll put sum pix up
06-20-2011, 12:06 AM | #73 |
lol I'll just take those ends off my slash lol
07-05-2011, 09:28 PM | #74 |
08-14-2011, 02:17 PM | #75 |
08-14-2011, 03:54 PM | #76 |
That die job is sick looking ! Great job, post up some video. Curious how that brushless works with that chassis.
08-15-2011, 04:28 AM | #77 |
OK guys...thanks for the orders. Right now, all I have left is: 2 purple 2 grey 2 red Casey |
08-15-2011, 04:32 AM | #78 | |
Casey Last edited by KC_JoNeS; 08-16-2011 at 01:53 AM. | |
08-15-2011, 05:08 PM | #79 |
Pebble Pounder Join Date: Nov 2010 Location: flagstaff
How are you's dyeing the pd ?? used search and found out thx
08-16-2011, 01:49 AM | #80 |
I have a system that works pretty good for the Rit Dye process. I use those chicken basting aluminum pans (4" deep) First, preheat the oven to 220 degrees boil water over the stove then I pour the water into the aluminum pan I mix in the color I want and stir add the bits that you want colored Then stick the pan in the oven until the desired color is reached That system was used to make these Casey |
