06-10-2011, 09:14 AM | #1 |
Pebble Pounder Join Date: Feb 2011 Location: Nashville, TN
| *** Tekin fxr 55t combo ***
I picked up a fxr 55t combo and I am wondering which spur and pinion to run thanks in advanced for any info
06-10-2011, 09:53 AM | #2 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
I would use the 87t spur factory and a 14t pinion. unless you want a little more wheel speed go with a 16t pinion. Thats my .02 for what it is worth. |
06-10-2011, 10:01 AM | #3 |
06-10-2011, 10:06 AM | #4 |
Good deal thanks guys |
06-13-2011, 11:29 PM | #5 |
Ok well I installed the fx-r esc with the 55t. I like how smooth everything is but I think I want just a little bit more wheel speed. Is 16 the biggest pinion I can run with out getting anything to hot? I've only had one other eclectic Rc usually run 1/5 scales.
06-14-2011, 12:09 AM | #6 |
What's your battery setup? That can give you some more wheel speed without changing the spur pinion combo.
06-14-2011, 12:12 AM | #7 |
As of now I run a 1500 2s lipo thinking of going to a 3s if it can handle it safely
06-14-2011, 12:28 AM | #8 |
3s will give you that wheel speed. Just get a castle creations external bec and you will be good. |
06-14-2011, 12:36 AM | #9 |
Allready got it hook it up without the red wire in the rx wire right?
06-14-2011, 02:17 AM | #10 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
I disagree with the findings thus far. Here are my happy settings. 35T motor - 16T pinion - 87T spur - 3S battery 45T motor - 18T pinion - 86T spur - 3S battery 65T motor - 20T pinion - 86T spur - 3S battery I prefer a good handwound motor so I can get the lowend torque and control...but I will not sacrifice my top end. The 65T motor I was using was just a lathe motor from RC4WD, and it did ok as long as I had a good size pinion gear on it. Casey |
06-14-2011, 11:30 AM | #11 |
06-14-2011, 11:31 AM | #12 |
06-23-2011, 10:45 AM | #13 |
I want more wheel speed what is the fastest pinion I can run? I have a 16t pinion stock tooth spur stock tranny gears 3s lipo as of now
06-23-2011, 12:34 PM | #14 |
How about changing to 35t HH Motor !
06-23-2011, 12:36 PM | #15 |
Tekin 55t
06-23-2011, 01:09 PM | #16 | |
06-23-2011, 01:10 PM | #17 |
damnit. i thought this was a give away... 55t machine wound? 87/20 on 3s is fun, but I'm a fan of wheelspeed, so i'd go 35 turn motor oon 87/20 gearing... |
06-24-2011, 09:36 PM | #18 |
Quarry Creeper Join Date: Apr 2011 Location: Mid TN
HH 35T torque master 540 pro is a beast! Plenty of wheel speed and torque. I use the 14 p and 87 spur. Overdrive front gears and under geared the rear. If I reverse and stab in forward it pulls front end off ground 3-4 inches and if I go forward and stab in reverse it will about flip over. I run 9.5 oz in ea front wheel and 3.5 oz in each rear and still has plenty of motor.
06-25-2011, 11:41 AM | #19 |
U guys think I can run a 18t pinion 87t spur with the tekin 55t on 2s now but will be making the swith to 3s soon
06-27-2011, 11:09 AM | #20 |
If you are looking to turn those wheels fast it is the way to go. I think at first you will have many emotions .
