06-23-2011, 01:18 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: Gila & Cibola
| need some steering help
Can i get more ackerman angle by just lengthening the drag link to create toe out? thanks |
06-23-2011, 01:28 PM | #2 |
Kinda, but not really. Ackerman is derived from the position of the mounting point of the tie rod in relation to the pivot point of the knuckle. Adding toe out will kind of have the same effect, though it won't be true Ackerman. It works though, I've done it. |
06-23-2011, 01:33 PM | #3 |
Rock Crawler Join Date: May 2011 Location: SoCal
If ackerman is a good thing to have, why do so many people recommend the VP zero ack knuckles?
06-23-2011, 01:38 PM | #4 | |
Zero ackerman keeps the wheels turning at the same angle which will decrease overall steering but helps to keep the tires out of the shocks. | |
06-23-2011, 01:41 PM | #5 |
"The dude abides!" The pivot point of the knuckle would be the "king pin" right? And the "mounting point" of the tie rod is on the steering arm of the knuckle? i still am using stock knuckles and what i think are stock length steering links, but it looks like i have a "less ackerman" thing going on. Is there true ackerman built into a stock ax-10 front axle? (inside wheel turning more) How do you tune yours? thanks |
06-23-2011, 01:45 PM | #6 | |
Man, i hate typing the word ackerman. | |
06-23-2011, 01:46 PM | #7 | |
I believe stock knuckles have ackerman built into them. Whether or not they are "true", I have no idea. I run VP's zero ackerman high steer knuckles on my rig. The arms are a straight shot out from the pivot point. Looking at your stock knuckles you will see that the arm is set at an angle, that is where the ackerman comes from. | |
06-23-2011, 01:48 PM | #8 |
06-23-2011, 01:50 PM | #9 | |
06-23-2011, 02:11 PM | #10 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
It looks good, you might could use a little more toeout, if your not already into the shock. What axle shafts are you running? Stock dogbones, CVD's? I think thats where your limits are.
06-23-2011, 02:13 PM | #11 |
For a stock setup, that isn't horrible. I would reset things so that the front wheels are either parallel or slightly toed out. You might also try them slightly toed in, sometimes that works too. When you get real serious about maximizing your steering, you'll need different or adjustable offset wheels to widen the track width. You'll gain some much needed shock/tire clearance. |
06-23-2011, 02:31 PM | #12 | |
Sketches here: http://en.wikipedia.org/wiki/Ackerma...ering_geometry Note the second sketch is showing rear-steer. It's very difficult to get 100% ackermann with front-steer. The steering arms need to be where the tire sidewall is. Short answer, my stock-steering AX10 does not have ackermann correction. It toes in with turning. Should toe out. So I use clearly visible static toe-out to compensate. | |
06-23-2011, 02:54 PM | #13 | |||
06-23-2011, 05:23 PM | #14 |
Stock steering knuckles have reverse ackerman when the tie rod is in front of the axle. A BTA setup will have proper ackerman with the stock knuckles. Running a gob of toe out works just fine with stock knuckles, but it looks funny. My Honcho has 1/4" to 3/8" toe out. Looks goofy, turns great. |
06-23-2011, 05:57 PM | #15 | |
I've only ever run a drab of toe-out. I'll have to try a gob and see how that works out. Last edited by WAM; 06-23-2011 at 05:59 PM. | |
01-02-2012, 06:47 PM | #16 |
Rock Stacker Join Date: Jan 2009 Location: Rio Rancho NM
| Re: need some steering help
Hey, duuude thanks for explaining this so good and putting that link! I'm having problems with my tires hitting my shocks too. Last edited by 505tj; 01-02-2012 at 06:52 PM. |
01-02-2012, 07:10 PM | #17 |
will these work? http://www.rcplanet.com/Axial_Zero_A...p/axi30778.htm I just bought new aluminum steering knuckles so I don't want to buy a complete new set with zero ackerman. Last edited by 505tj; 01-02-2012 at 07:13 PM. |
01-02-2012, 07:40 PM | #18 |
Those should give you 0 ackerman, but they won't fix the issue with your shocks being in the way. Eventually you're going to want more steering and to make room for that you're going to have to figure out how to tip your shocks further inboard, stand them up straighter, or get an entirely new chassis.
01-02-2012, 07:57 PM | #19 |
More steering was going to be my next upgrade. I just bought this chassis' and it cost me a pretty penny, I guess I need to look into all my options with modifying what I got.
01-02-2012, 08:39 PM | #20 |
Quarry Creeper Join Date: Sep 2011 Location: NW
| Re: need some steering help If you have just a stock ax axle your rig will be narrower then an XR. Try upgrading to a "chris the battery guys" narrowed Wrath housing, Highland crawler berg universals and Vp chubs/steering blocks. You can you use your stock gears. This will make your front end wider to clear your shocks and add more steering. Every addition (your chassis) will create a new issue. That's part of the fun. Good luck.
