07-08-2011, 11:30 PM | #1 |
Rock Stacker Join Date: Aug 2004 Location: wasatch front
| Ax-10 for $200
I have A chance to pick up a used ax10 for $200. It is stock from what I can tell. Is this a good deal or not?
07-08-2011, 11:32 PM | #2 |
Newbie Join Date: Mar 2011 Location: OMAHA
Thats almost new. I would check out the for sale section on here and get one that way. Might find a fixed up crawler or fastback etc.
07-08-2011, 11:32 PM | #3 |
Rock Stacker Join Date: Feb 2010 Location: ashland
07-08-2011, 11:50 PM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
If it's completely stock that isn't that great of a deal. You can get a brand new one for $240 at Amain Hobbies and $235 from CKRC. Look around you can find coupons for amain to help out with shipping.
07-09-2011, 12:00 AM | #5 |
Quarry Creeper Join Date: Jul 2011 Location: Monterey, CA
07-09-2011, 01:34 AM | #6 |
Newbie Join Date: Mar 2011 Location: brisbane logan qld
the ax10 rtr needs alot of work to fix the weak points so if you can find one that has been moded it would be cheaper
07-09-2011, 08:37 AM | #7 |
it looks like it has aluminum links, losi tires, 2 batteries. i think they are NimH all the electronics and a charger.
07-09-2011, 02:14 PM | #8 |
does it have an ESC or radio? The ESC is pretty important especially if you want to run lipo batteries (which I highly recommend). The older stock axial ESC (The AE-1) does not have a low voltage cut off whereas the new ESC (AE-2) does have the cutoff and is much more desirable.
07-09-2011, 05:17 PM | #9 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
I'm with the rest...if it's pretty much all stock i'd hold out and get one on here. look for one with upgrades, chassis, tires, electronics. I see nice ax-10's that are upgraded for around $200-$250 frequently on here.
07-09-2011, 09:36 PM | #10 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
yep, I wouldn't pay over $150 for a near-stock rig, and that would have to be nearly new.
07-12-2011, 12:23 PM | #11 |
Newbie Join Date: Jun 2011 Location: USA
I'm also in the same spot, I've been searching for an ax10 and I've found one that is reasonable for $150 used, its being sold as RTR. I've had quite a few RC's in the past but I'm looking to get into the crawlers. The deal I have lined up is "fair" but the truck looks used. I wanna check out the classified section but I dont have 30 post and I've not been a member for 30 days. If I could find a better deal for 200 I'd jump on it. No way around the forum restrictions though.
