08-14-2011, 04:42 PM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Elk Grove
| Ax10 chub bushing?
I was messing aroundvon a camping trip and lost the hat bushing that goes into the chub, are these readily available at most LHS'S?
08-14-2011, 04:55 PM | #2 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
Not where I live, but if your LHS carries Axial, they should have em. If al else fails get em from RPP.
08-14-2011, 04:57 PM | #3 |
I would assume so. Axial calls them " flange pipes" but most call the " top hat bush ins.". Erik D Lux sells a no slop version in the vendors section, but the are knuckle specific.
08-14-2011, 05:52 PM | #4 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
If you are getting new ones, you should try these. They are true to their name. NO SLOP king pin bushings. AX10, Berg, SCX10 |
08-14-2011, 06:00 PM | #5 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
HPI makes ones exactly the same as Axial but way cheaper.
08-14-2011, 10:03 PM | #6 |
Thank for help guys, I'll check out DLux's stuff as well as HPI. |
08-15-2011, 02:35 AM | #7 | ||
08-16-2011, 04:50 PM | #8 |
Can someone verify that D_Lux's version 1 will work with Vanquish NON-zero-ackerman knuckles? For some reason I think that my version has a thicker than normal top kingpin. |
