10-10-2011, 03:18 PM | #21 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
10-10-2011, 03:37 PM | #22 | |
Rock Stacker Join Date: Aug 2008 Location: tamworth, nsw, australia
I do believe GOATSNIPER has done the same....I know I got decent pics in my build thread, GoatSNIPER should have some too to show what can be done.... | |
10-11-2011, 05:42 PM | #23 |
Thanks slowlearner. I did check out goatsniper's build along with your build and both are helpful. I will get some pics of my rear lower/drive shaft clearance and dig clearance issues when I get all my parts. Thanks again. |
10-16-2011, 06:03 PM | #24 |
Well I got to do a little work during the Niner Victory Got the BWD HD motor plate and motor guard installed. Intalled the new dig servo. Finally addressed the dig clearance issue. Fix was simple, thanks to a fellow member giving the idea to just flip the screw that was in the way of the servo arm. Nest I moved the shocks inboard on the included mount. The plan was to get more steering. This is a view from underneath the front axle showing how I moved the shocks and lower links around. And the result, a lot more steering. Now the upper links hit the shocks on full compression of the suspension, I think Ill need a spacer between the frame and upper link rod end, maybe not. I was also able to stop the contact between the rear lower link and the driveshaft, just switched from high clearanc Crawler Innovations delrins to Medium clearance Crawler Innovations delrin lowers I am now working on all the electronics and body panels. Just ran out of zip ties off to OSH. Ill update when finished |
10-16-2011, 07:22 PM | #25 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
Man there not joking about the tightness with dig in this chassis. Thanks for the close up pics and nice job. Gotta get my links inside like that
10-16-2011, 08:59 PM | #26 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
Lookin good man, glad you got it all to fit. Honestly though, that horn is serious overkill for the dig servo. I've been running cheapo dynamite aluminum horns on my dig servos with no probs for over a year now (first was a spectrum s200 then a hitect mg225)
10-16-2011, 11:42 PM | #27 | |
10-17-2011, 12:00 PM | #28 |
Rock Stacker Join Date: May 2010 Location: canvey island essex
rig looks sweet but can i asked were you got the rear d link bracket from and also the dig servo bracket |
10-17-2011, 01:00 PM | #29 |
10-17-2011, 01:28 PM | #30 |
10-17-2011, 04:20 PM | #31 |
10-17-2011, 06:07 PM | #32 |
Well I got all the electronics in or "crammed"Body panels are now mounted but with extra holes in one side panel may have to make a new one (OCD). It turned out OK I guess. Love the chassis (thanks Juan). I just hope whats holding my ESC in place and a couple of zip ties do not let loose or my electronics are in a world of hurt (spur gear). may look into a vanquis spur cover (if it fits). Now for a test on my little side yard course. So here is the final build list: AXLES FRONT: Axial heavy duty R&P MIP CVDs HR heavy duty spool RCP Chubs Gunnar Beef Tubes REAR: VP lockouts VP Razor Shock Mounts Axial Straights UGC D Mount Axial heavy duty R&P Gunnar Beef Tubes STEERING Hitec HS 7950TH JonesN BTA SteeringLink VP Zero Ackerman High Steer Knuckles SUSPENSION 4 link front / 4 link rear Axial Comp Shocks Crawler Innovations (slight bend rear lowers) Vanquish (titanium front lowers) Traxxas Revo rod ends DRIVETRAIN VP transmission housing HR aluminum gears, spur/mount VP Hurtz Dig Hitec HS5245 Mighty Mini dig servo MIP cvd drive shafts WHEELS & TIRES Hot Bodies Rovers (white) Crawler Innovations Double Deuce Foams Mayhem Engineering Competition Double Phattys ELECTRONICS Holmes Hobbies BR-XL w/ 35T HH brushed motor, Spektrum DX3R w/ sr3100 receiver, Holmes Hobbies 1300mah 11.1v 3s Lipo Still to come: Upper links (Lunford 3/16") Flip some of my tires (realized Rovers are directional! Any help?) Maybe a Vanquish Spur Cover. Rowdy Racing Servo Armor DLux knuckle bushings (slop!) Delrin spring cups (cant remember the maker, CI sells them) Ill try to post some action pics later. |
10-17-2011, 07:04 PM | #33 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
Flipping the rovers is literally a 1 minute affair. Hit a line 5 or 10 times then swap the tires, go back, and hit it another 5 or 10 times. I have noticed they make more forward traction in one direction and are a bit less likely to bounce off track in the other. |
10-18-2011, 12:02 PM | #34 |
10-29-2011, 06:38 PM | #35 |
Rock Stacker Join Date: Oct 2011 Location: milan
| Question
I am getting a Fastback Monday. Where did you get the D link mount for it? I am new to this site. Could you please help out.
10-29-2011, 07:48 PM | #36 |
10-30-2011, 07:52 AM | #37 |
Newbie Join Date: Oct 2011 Location: eastern sierra
What material did you use to make the body panels?
10-30-2011, 03:13 PM | #38 |
01-03-2012, 08:42 PM | #39 |
Quarry Creeper Join Date: Nov 2011 Location: Cookeville
| Re: NorZepol's UGC Fastback II Build
Whats is the Front lower links eye to eye and rear lower links eye to eye ?
01-03-2012, 11:16 PM | #40 |
| Re: NorZepol's UGC Fastback II Build Theres plenty of threads stating lengths of your lowers. But for the hell oft 5 1/16th rears and 4 1/4in fronts should get you in a good ball park. Might need some minor adjusting to suit your style though |
