11-30-2011, 01:22 AM | #61 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
11-30-2011, 12:48 PM | #62 | |
The good news though is when the steering did work, it worked well. I was able to make lines that I know would have required a few reverses with my old dog-bone setup. Going to start flipping things around tonight, and get my steering strength back. | |
12-15-2011, 07:30 PM | #63 |
Rock Stacker Join Date: Oct 2011 Location: milan
| Re: C*H*U*D's Sporty
I have a fastback with axial parts iam looking to put the no slop lockers in.Do i put them both front and back and do i put the same part #ax30402 in front and back.Iam new here and thanks for the help .
12-15-2011, 08:39 PM | #64 | |
| Re: C*H*U*D's Sporty Quote:
AX30402 is the 43T/13T combination. They are Underdrive gears and would go in the Back. Ax30401 is the 36T/14T combination. They are Overdrive gears and would go in the Front. You can use them individually or together. I have both Overdrive in the front and Underdrive in the rear. Great to see you here and welcome to RCC Tracy Last edited by C*H*U*D; 12-16-2011 at 09:23 AM. | |
12-16-2011, 02:54 AM | #65 |
Who sells the no slop lockers and how much are they.And i love this fastback chassis.thanks again tracy |
12-16-2011, 09:11 AM | #66 | |
http://www.rccrawler.com/forum/axles...p-lockers.html . | |
12-16-2011, 09:25 AM | #67 |
Just got a PM from JeremyH correcting my post over which gear set was overdrive, and which was underdrive. Here is the correct info: AX30402 is the 43T/13T combination. They are Underdrive gears and would go in the Back. Ax30401 is the 36T/14T combination. They are Overdrive gears and would go in the Front. I corrected it in the post above as well. Thanks Jeremy |
12-16-2011, 09:29 AM | #68 |
| Re: C*H*U*D's Sporty |
12-16-2011, 06:54 PM | #69 | |
Pebble Pounder Join Date: Oct 2011 Location: loveland
12-19-2011, 09:39 AM | #70 |
Hi this is tracy i sent the guy the money for the no slop lockers.But he did not take it is he still making tthem call me asap.thanks |
12-19-2011, 10:04 AM | #71 |
Hey Tracy, good to see you made it on to RCC. Have you started a build thread yet? |
12-19-2011, 12:26 PM | #72 |
is he still selling the no slop lockers. |
12-19-2011, 03:09 PM | #73 |
As far as I know he is. Not sure why your payment got sent back to you. You can try sending him a PM and asking what happened.
12-22-2011, 09:36 PM | #74 |
A few changes have taken place since this update, so I'll try to include everything. First of all, I finally got another set of Bigbores. The reds seem a bit soft, so I plan to swap in some orange before next week. Here is an underneath shot...someone asked me for this awhile back, and I can't remember who, but here it is. Those are M3 X 35mm bolts on the bottom: My old wheels are 1.25" wide. I started running 1" on my XR and really liked them so I wanted to get a set for the sporty, so I picked these up from the Crawl Space this week...thanks for the help Tiff Sexy huh? Too bad they won't be seen: My old wheels carried all their weight towards the inside beadlock. I wanted narrower wheels, but also wanted to change where the weight was carried. The brass beadlock puts 4 oz. as far out as it can go. I plan on knuckle weights to pick up the remaining few ounces which is why I went with SLW's. Ouch!...not sure how this happened, but I found it today while swapping tires. Last edited by C*H*U*D; 12-24-2011 at 06:50 AM. |
12-22-2011, 11:29 PM | #75 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
From the back shot of the rim it looks like you could open the weight ring center hole up and put it behind the spokes with longer bead lock screws..unno just a thought.
12-23-2011, 01:09 AM | #76 |
Those rims are purrty... And actually the brass ring looks pretty good.. Nice addition to the build |
12-23-2011, 07:32 AM | #77 |
| Re: C*H*U*D's Sporty I would have to decrease the OD which would make it lighter, and it would also defeat my goal of putting the weight as far to the outside as possible.
12-23-2011, 08:11 AM | #78 |
Makes total sense. Just dont think I could hide all that sexyness myself awesome rig and great inspiration |
12-23-2011, 08:35 AM | #79 |
12-23-2011, 08:44 AM | #80 | |
I looked at this last night, and you're absolutely correct. The tire got pushed over into the screw for my tie-rod. The threads must have caught the rubber and tore the hole. | |
