12-24-2011, 10:33 AM | #61 |
Quarry Creeper Join Date: Nov 2010 Location: Toronto Canada
| Re: Y U NO Crawl? - Axial Mod 3.0
Awesome rear clearance, thankfully sporties are making a strong come back. We may have a decent sportsman class come the 8th. With only one person currently signed up for it, it doesn't seem like it will be very competitive. Last comp I came first, not because of my driving but only because there were only 3 of us and I was the rig that did not break.
12-24-2011, 11:19 AM | #62 | |
Pebble Pounder Join Date: Sep 2009 Location: Canada
| Re: Y U NO Crawl? - Axial Mod 3.0 Quote:
12-24-2011, 11:48 AM | #63 |
I should be in for sportsman and pro. Shouldn't be very successful since both rigs are practically all new with no testing, I guess I'll keep my fingers crossed LOL.
12-24-2011, 03:16 PM | #64 |
final shot with the body on. |
12-24-2011, 03:51 PM | #65 |
Hurry up and go drive it already!
12-24-2011, 04:33 PM | #66 |
| Re: Y U NO Crawl? - Axial Mod 3.0 |
12-24-2011, 11:43 PM | #67 |
Holy shizz man... This is sweet. I cannot belive that this is a sporty rig with all that break over. You did this one up right... Very nice job man |
12-25-2011, 08:36 AM | #68 |
thanks dude. ya its my design. the rear links were made by delux, designed by me. is it a sporty though with a dig? the rear links really complete the concept. Last edited by Jessf; 12-25-2011 at 08:40 AM. |
12-25-2011, 08:47 AM | #69 |
Rock Stacker Join Date: Apr 2009 Location: sheilock
| Re: Y U NO Crawl? - Axial Mod 3.0 damn that sure is a sweet rig you got there and no dig in sporty class! 2.5 – Sportsman Class (Optional): ▪ 2.5.1 - Vehicle wheelbase is limited to a maximum of 12.5 inches. ▪ 2.5.2 - Vehicle track width is limited to a maximum of 12.5 inches. This is determined by measuring the bottom of the outer most edge of the front and rear tires while the vehicle is sitting on level ground. ▪ 2.5.3 - Vehicle is limited to 2.2 inch wheels/rims or smaller at the bead surface. Wheels may be modified, provided that the tire bead surface does not exceed 2.2 inches in diameter. With a tire mounted, no exterior component of the wheel, including but not limited to, the bead lock ring shall exceed 2.55". Tires may be modified from other sized tires using only a pliable rubber, but must not exceed a total uncompressed outer diameter of 6 inches. ▪ 2.5.4 - Vehicles are limited to 2-wheel steering only. ▪ 2.5.5 – The body and Bodiless vehicles same as Class 2 vehicle –2.2 (See Sec. 2.3.5 & 2.3.6) ▪ 2.5.6 - Vehicles are limited to the use of 2 radio channels (one for steering & one for throttle) only. Neither channel can be used to perform more than one function. Radio systems with more than 2 channels are allowed, but only 2 channels may be used to control the vehicle. ▪ 2.5.7 - Vehicles are limited to 1 ESC & 1 servo only. ▪ 2.5.8 - (OPTIONAL) Vehicles are limited to 1 motor powering both of the axles. |
12-25-2011, 09:14 AM | #70 | |
thats what i thought. without a dig id have to upgrade the rear shaft to the tmax, theres nothing long enough otherwise Quote:
12-25-2011, 06:56 PM | #71 |
Sorry bro... I thought that it was a sporty... My bad i was tired when i posted But still killer break over for a shafty |
12-25-2011, 10:06 PM | #72 |
12-25-2011, 10:53 PM | #73 |
12-26-2011, 12:06 AM | #74 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
Turned out sweet Have you had any drive time, how does it sidehill? The break over is sweet! Nik |
12-26-2011, 08:10 AM | #75 |
| Re: Y U NO Crawl? - Axial Mod 3.0 ya i've had some drive time with the delrin rear links but zero drive time with the new TI links, evos and xros. Even with the delrin links I was able to pull out of vertical climbs over rock edges without touching bottom. I may get some drive time in tomorrow at GTA.
12-26-2011, 09:35 AM | #76 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
The build came out great, MOA ground clearance with a shafty,very nice. |
12-26-2011, 11:31 AM | #77 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
you can run an extended output on the back of your transmission in place of your dig unit. if you want to turn it into a sportsman truck.
12-26-2011, 12:35 PM | #78 | |
Rock Crawler Join Date: Jun 2011 Location: San Diego
I'm waiting for someone to frontside jones on a big rake like this. The IC and antisquat would take care of itself. You could probably get away with mounting the rear links on top of the axle to use smaller bends closer to the chassis. Stop making me rebuild my car, Jess! | |
12-26-2011, 09:53 PM | #79 |
RCC Addict Join Date: Aug 2007 Location: Toronto, Canada
Just found your thread tonight, awesome setup. Subscribed. |
12-28-2011, 04:29 PM | #80 |
had it at GTA hobbies earlier today. broke a trans gear, still running the stock nylon gears. apart from that the rig crawled as expected, better than my driving. |
