11-18-2011, 11:28 AM | #41 | |
That should open up a ton of space to run the maxx shaft | |
11-20-2011, 02:57 PM | #42 |
.....and then? I haven't got any PM's lately so I'm guessing it's done and on the rocks. |
11-20-2011, 04:09 PM | #43 |
11-20-2011, 04:19 PM | #44 |
11-20-2011, 05:02 PM | #45 | ||
I don't wanna get anything started with Duuuuuuuude. Yet, | ||
11-21-2011, 12:40 PM | #46 |
Thinking about making the plates from 1/16" Carbon fiber. Would the 1/16 be too thin? 1/16 is ~1.5mm thick, what is on there now is ~3mm thick. And I just ordered Lunsford Racing Titanium Rock Grinder links for the whole truck. ... Last edited by Szczerba; 11-21-2011 at 12:48 PM. |
11-21-2011, 01:14 PM | #47 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Looking forward to seeing this one run, do you think Mike gave you all his secrets. |
11-21-2011, 01:24 PM | #48 | |
He must have had a cup of coffee or something right before I pm'd him. But really, thanks for the info Mike . | |
11-21-2011, 01:27 PM | #49 |
Still got to drive it. |
11-21-2011, 09:43 PM | #50 |
| Rear Axle Done
Longer beef tubes on rear axle. Didn't have any c-clips to hold the rear axle shaft in, so I just added some barrel spacers to do the job. Wheely King straight axles. Right about 8.5" hex to hex. 10.5" wide with SLW's and 225 hubs. Front axle next. Last edited by Szczerba; 05-25-2012 at 07:31 AM. |
11-22-2011, 08:27 AM | #51 |
| 1/16th should easily do the job.
11-22-2011, 11:07 AM | #52 |
11-22-2011, 12:09 PM | #53 |
You'll be happy with that I'm sure.
11-22-2011, 09:03 PM | #54 |
Front axle done up with longer beef tubes, XR10 >> chubs, knuckles, universals, knuckle weights. Clocked em back to whatever degrees and hopefully they are close to the same . Just wanted a some and be able to get the steering link close to the axle housing. 475 hubs puts it right at 11". Plenty of wiggle room to jump down a hub size and still be able to get 3 rings on the knuckle weights. Plenty-o-steering... |
11-22-2011, 09:19 PM | #55 |
Cheater!
11-22-2011, 09:21 PM | #56 |
11-27-2011, 06:13 PM | #57 |
Solved the front driveshaft issue. Drilled the ends out to just over 6mm. The "D" slot on the female end off the Junfac shaft doesn't run the full length of the shaft. Cut the "D" part of the female end and re-welded to the universal part. Driveshaft is about 55mm long. And use "pass through" pins. Setup the Titanium links to get right at 12.35" wheelbase maxed out. Used Jato ends on the lower rears and then cut them down a few millimeters to get the right wheelbase. Cut and countersunk a 3mm piece of carbon fiber for the servo/link mount. I was going to BTA the drag link with the servo turned the other way but gave up after an hour and various drag link bends. 1.5mm carbon fiber should be in soon, I'll re-cut the chassis this week. Electronics will go on a small CF plate that will be attached to the servo/link plate. Still figuring out battery placement but I have an idea. .... |
11-27-2011, 08:17 PM | #58 |
What an amazingly clean workbench. I'm jealous.
11-27-2011, 08:23 PM | #59 |
Rock Crawler Join Date: Dec 2009 Location: Jersey Strong!
Nice work on the build Shane. I may have missed it but what shafts are you using in the rear axle, XR10?
11-27-2011, 08:57 PM | #60 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
| Wow Shane, I know I saw this in person at the Turkey crawl and was very impressed BUT after reading this build thread I just have to say WOW, You have definitely put in some impressive work and I can’t wait for more IM starting a sporty build very soon but it wont be near the rig your is |
Szczerba's FF-SZ 2.2s - Similar Threads | ||||
Szczerba's F-Toy #744 | Szczerba | 1.9 Scale Rigs | 240 | 02-17-2022 08:32 PM |
Szczerba's JK (Minus some doors) | Szczerba | G-Made Crawlers | 193 | 11-06-2012 07:26 AM |
Szczerba's Trophy Truck Build.. With Videos | Szczerba | Non Crawler RC's | 110 | 07-18-2012 09:34 PM |
Was Szczerba's Defender 90 Build. On to the Next. | Szczerba | 1.9 Scale Rigs | 22 | 07-07-2012 05:18 PM |
Szczerba's Cherokee (Minus some doors) | Szczerba | Axial SCX-10 | 166 | 03-25-2012 07:45 PM |
