12-13-2011, 03:22 PM | #21 |
Rock Crawler Join Date: Sep 2010 Location: Little Rock, AR
Your drivetrain is on its way sir. The rear axle is ready to rock just bolt on your link plate, it was greased and waterproofed after i installed the new case and xhd locker, so don't pull it apart unless you want nasty hands. the other XHD locker is in the box for you to rebuild the front with.
12-13-2011, 03:23 PM | #22 |
12-13-2011, 03:27 PM | #23 | |
ahh sweet you threw in a tranny too? thanks Rootar, you're the best. I'll have some nasty hands because there is no need for a waterproofed axle on a comp truck. either way your efforts are much appreciated. go team ram rod | |
12-13-2011, 03:35 PM | #24 | |
No joke wear latex gloves the grease i use around the perimeter of my axle cases is NASTY, it also stinks, and itll stain your pretty little hands. Youll have more than enough fun with the front axle to worry about the rear. and yes minus a case, a top shaft, and some bearings you have a tranny as well. i kept my green gates you bastard | |
12-13-2011, 08:24 PM | #25 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
Great start Ashton, I was digging the V1 but after seeing the V2 I am very impressed. It looks like its gonna be very trick It reminds me of a baby kitten My Sporty build is in parts just sitting on a bench collecting dust and it will never be as cool as yours |
12-14-2011, 10:59 AM | #26 | |
| rats Quote:
It sounds like you have something up your sleeve? Get to cracking with the beans spillage. (in your own thread, though) | |
12-15-2011, 12:37 AM | #27 |
| Re: helhedded's Comp Shafty
While I'm waiting on parts to finish the build I decided to go ahead and start messing with the wheel and foam setup. I will be using some prototype inner foams that Eddie at Crawler Innovations has been working on for a while now. I have had great success running them in Khaos tires on my berg so I had to have some for this build. They are a closed cell foam pre-cut to 1.75". From my understanding they will be offered in different widths for different wheel sizes. A channel is machined out to leave room for the tire bead. Without that channel properly mounting tires with these foams would be nearly impossible because they are so dense. One prototype foam weighs 6.7 grams which is less than one of my regular firm inners that weighed over 7 grams. I have been a firm believer in running an inner support ring but they are now unnecessary with the new inners. I think it's better than running a ring because these foams cover the whole wheel. I will be testing these on this truck with some siped white dot Rovers. They will be complimented with some all-adjustable aluminum 1.25" Mayhem Evo bead locks. I won't have any clearance issues with these! I like to vent my wheels so I needed to vent the foam too. I like to use a body reamer. You have to make sure that you make the hole large enough to compensate for a little foam "squish" once they break-in. Other people will probably just vent the tire. CI PROTOTYPE closed cell inner foam outfitted with a 5.5" CI soft outer Last edited by helhedded; 01-02-2012 at 07:40 PM. |
12-15-2011, 07:52 AM | #28 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
| Re: helhedded's Comp Shafty I'm dying to get my hands on a set of those!
12-15-2011, 08:40 AM | #29 |
| Re: helhedded's Comp Shafty |
12-15-2011, 08:56 AM | #30 |
Yeah I'd like to get ahold of some myself. |
12-15-2011, 09:01 AM | #31 |
Nice! I've seen Shelby's proto foams a few times and I can't wait for them to come out...
12-15-2011, 11:09 AM | #32 |
Well I want a set too, Damn it!!!! I like that sipe pattern on the Rover as well |
12-15-2011, 12:27 PM | #33 |
Don't forget the vent holes! I drill about 8, 1/4" holes around the foam. ... 3mm carbon fiber front and rear 4-link plates are done. Just waiting on the USPS for the V2 chassis templates and I will get to cutting the 1.5mm. Should be in a few days and they'll be heading back your way. |
12-15-2011, 12:38 PM | #34 | |
| Re: helhedded's Comp Shafty thanks. I borrowed that idea after I saw a pic of John Ripplinger's rovers at a west coast qualifier. Quote:
12-15-2011, 12:43 PM | #35 |
Ashton those foams are looking very interesting, I'll hold off on new tire foam for awhile. |
12-15-2011, 05:17 PM | #36 |
I'm a firm believer in firm inner foams also. I've heard of these trick foams. Now I've seen a pic. Now I want!!! |
12-15-2011, 05:30 PM | #37 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
12-15-2011, 05:45 PM | #38 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
Is the middle ring the firmest or is the inner ring the firmest? And can anyone comment on why? <3's all around, thanks in advance!
12-15-2011, 08:07 PM | #39 | ||
| Re: helhedded's Comp Shafty Quote:
There is a little more info in this thread Crawler Innovations Khaos Rover Comp Tire It's one foam. What you are calling the "inner" is actually the same black foam but it is channeled out to leave room for the tire beads. Last edited by helhedded; 12-15-2011 at 08:21 PM. | ||
12-16-2011, 07:36 AM | #40 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
name for your chassis.. "lightrunner" |
