12-16-2011, 07:42 AM | #41 |
| Re: helhedded's Comp Shafty |
12-16-2011, 07:45 AM | #42 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
12-16-2011, 07:50 AM | #43 |
The axles that I'm using for this build will be some beefy AX10s that I picked up from my buddy Rootar. These axles are pretty sweet and he gave me a decent deal on them. Thanks, Doodar! They showed up yesterday and I started the tear down and cleanup of the front axle last night. The front is equipped with: Super 300 axles and locker 36/14 gearing Gunnar beef tubes VP Zero Ackerman knuckles unknown c hubs I should be able to get it put together tonight. I got tired last night and had to lay down for my beauty sleep. |
12-17-2011, 07:08 AM | #44 |
..legacy.. c.l.u. - carbon lightweight unit |
12-18-2011, 06:23 PM | #45 |
here's a peek at the new plates |
12-18-2011, 07:08 PM | #46 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
Looks great Ashton Your "macshaneist" does good work |
12-18-2011, 07:10 PM | #47 |
12-18-2011, 07:24 PM | #48 |
RCC Addict Join Date: Nov 2006 Location: southaven
meh |
12-18-2011, 07:39 PM | #49 |
12-18-2011, 08:02 PM | #50 |
I hand cut them using Helhedded's lexan templates. Chassis plates are 1.5mm CF, front/rear 4-links are 3mm CF. The 3mm CF likes to splinter and delaminate real easy. Not sure if it was my drill bit or just the CF. I took all the pre-cautions for prep and while cutting to not have them splinter/de-laminate. Just used a dremel with a metal "thin" cut-off wheel and a sanding drum "stone type" for the dremel. Going in the mail tomorrow. |
12-18-2011, 08:53 PM | #51 |
awesome job shane! look forward to seeing this together.. |
12-19-2011, 06:03 AM | #52 | |
| Re: helhedded's Comp Shafty Quote:
12-19-2011, 08:11 AM | #53 |
12-19-2011, 08:52 AM | #54 | |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
12-19-2011, 08:56 AM | #55 |
12-19-2011, 10:09 AM | #56 |
Man, you really need one of these... |
12-19-2011, 04:55 PM | #57 |
12-22-2011, 01:27 PM | #58 |
the post man dropped this off today... What could it be? links? Electronics? An official Red Ryder carbine-action two-hundred-shot range model air rifle? I'm not even sure if I should open it because Sir Spanksalot doesn't even live here. Harry Paumbs does, though... |
12-22-2011, 01:29 PM | #59 |
Well that bites. Probably ought to send it back just to be safe.
12-22-2011, 01:55 PM | #60 |
