12-29-2011, 04:24 AM | #101 |
| Re: helhedded's Comp Shafty |
12-29-2011, 09:04 AM | #102 | |
| Re: helhedded's Comp Shafty Quote:
Are you not impressed by 454 2.2 performance? lack thereof? Don't be coy cowboy! I've ran plastic gears before and as long as you aren't too hard on them- wait nevermind. I'm used to a berg. What in the hell am I thinking.. Last edited by helhedded; 12-29-2011 at 09:07 AM. | |
12-29-2011, 09:10 AM | #103 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
I actually run a bone stock trans in my sporty. However, I still run 'pede plastic drive shafts which help absorb some of the torque that would normally destroy stock gears or outputs.
12-29-2011, 09:12 AM | #104 | |
I'll be running metal driveshafts on this rig, so I better stick with all metal gears. I have them sitting on my work table, I just need the tranny to show up from TCS so I can get it built. | |
12-29-2011, 09:18 AM | #105 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
12-29-2011, 09:19 AM | #106 |
12-29-2011, 09:21 AM | #107 |
| Re: helhedded's Comp Shafty I'm all about some trannies. I just had one in my hands last night! It was an old one, though. Now I just need my beefy shafts and my shiny new tranny in the same room so they can start working together.
12-30-2011, 01:38 PM | #108 |
More loot showed up! I'm going to give the JunFac shafts a try and the tranny gears are from Robinson (thanks Rootar!). I used Hair & Grease drain cleaner from Home Depot to strip the anodized parts. I think that this stuff works better than Easy Off. I had this motor as a backup for my berg but for the time being I'm going to use it for this build. It's a 35t Holmes Hobbies Torquemaster Pro Handwound. I chose the 4mm web 3 slot armature for more power and rpms. Last edited by helhedded; 12-30-2011 at 01:40 PM. |
12-30-2011, 01:48 PM | #109 |
Good luck with those Junfacs.....I broke a few of them and the pins fell out of them on a regular basis.
12-30-2011, 02:31 PM | #110 |
| Re: helhedded's Comp Shafty A little ring of adhesive heat shrink wrap keeps those pins in check. Last edited by Duuuuuuuude; 12-30-2011 at 02:38 PM. |
12-30-2011, 02:49 PM | #111 | |
I'll give that a try once they go on the scaler. I like the smaller diameter, but MIP's are ready to go on the Sporty soon. | |
12-30-2011, 03:31 PM | #112 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
as long as you dont have alot of droop you'll be fine on the jun-facs driveshafts. keep them greased,heatshrink around the shaft to keep it in,and loctite the screws,and clean and oil them before running and they'll keep up. i had them on my foff rig and its running full droop. because of the halfmoon design it binds up on 1 side when the suspension falls out.. o.m.g. you are so slooooooowwww... ++ |
12-30-2011, 03:34 PM | #113 | |
12-30-2011, 04:14 PM | #114 | |
I couldn't agree more, my rig is sub four and a half pounds and the weight is low, wheel and knuckle locations. | |
12-30-2011, 04:58 PM | #115 |
12-30-2011, 05:37 PM | #116 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Man that's a great looking rig!!! I always lime building my own stuff like this also back when I had the WK. Got me thinking about all that spare Delrin I got laying around at the house!! If you want to run it when I'm home I will shoot some pics and video for ya. I need to get my crap together and get a scaler or something running soon! |
12-30-2011, 05:52 PM | #117 |
12-30-2011, 07:01 PM | #118 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
| Re: helhedded's Comp Shafty I let my front shaft bind at full extension and it's done nothing but shake the rig a little bit when it's high centered. I know it's probably not good for my tranny but I don't enjoy it as much when it doesn't shake!
12-31-2011, 06:08 AM | #119 | |
Mine aren't exactly just a stock 'pede shaft, though. I use two female and one male shaft to make each shaft. I cut the end off of the male shaft and CA it into a shortened female shaft. That way, there is only a small amount of exposed male shaft. This eliminated any twisting of the male shaft. Wow, between Ashton liking the trannies and me manipulating my male shaft, this thread is going down hill quickly! | |
12-31-2011, 07:40 AM | #120 |
I ran pede shafts back in my dig shafty days and they were a pain then. I've also had them on my YJ and they are still a pain. Why can't you guys just let me break some shit?
