12-31-2011, 10:08 AM | #121 |
| Re: helhedded's Comp Shafty
I hear Integy makes some shit. You could break that shit.
01-02-2012, 07:03 PM | #122 |
full bta and electronics are done |
01-02-2012, 07:09 PM | #123 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
BTA came out great, gets pretty tight with lots of caster, good job! |
01-02-2012, 07:11 PM | #124 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
Thats just flat out bad a** man. I can wait on the running videos of this rig |
01-02-2012, 07:15 PM | #125 |
Needs more caster. Good idea on the small washers for the chassis mount screws.
01-02-2012, 07:30 PM | #126 | ||
| Re: helhedded's Comp Shafty Quote:
Yeah the washers are a must. I still need to put a few more on there. | ||
01-04-2012, 06:13 AM | #127 |
Ashton, the truck just looks bad ass as hell. You've got yourself a nice one, it should kick some serious Sporty tail. |
01-05-2012, 11:41 AM | #128 |
| Re: helhedded's Comp Shafty |
01-05-2012, 11:58 AM | #129 |
So after Opek's post about IC I started digging around to learn about Squat, IC, COG and so on. It took me a while to figure it out but I think I got it. The truck drives great in forward, but there is some rear tire lift when going in reverse. Exactly what Opek stated would happen. Preloading the front drastically reduced this, but I'd like to figure out why the lift is happening. Is there an optimum location for IC? I found my cog using this method. Anti Squat and Suspension Tech post #374 It's the easiest way that I have found to measure it, but if anyone knows of a better way for a n00b please let me know. going off of this image rear squat front squat Raising my front upper on the chassis by one hole gets me closer to 100%, so I might try that out tonight. |
01-05-2012, 12:17 PM | #130 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
awwww chit... it's getn technical now.. looks good man! look forward to seeing C.L.U. on the rocks.. |
01-05-2012, 01:23 PM | #131 | |
I was driving back to work thinking about all of this and it hit me. Perhaps I need to think backwards to tune this out. According to the drawing I have a ton of antisquat in the back so I'm going to reduce that and see if it helps my problem. | |
01-05-2012, 01:44 PM | #132 | |
Two holes up on the front, 3-4 holes up on the rear! Then report back. | |
01-05-2012, 01:57 PM | #133 |
01-05-2012, 09:41 PM | #134 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
01-06-2012, 07:32 AM | #135 | |
Correct. My results will be slightly off due to me not having a body on the rig, but I can always "re-guesstimate" once I get a lid on there. Total weight in the pictures with tires is 5.3lbs, but there is roughly 8oz of knuckle weight on the truck. I should have this thing sewed up by this weekend ...got backtracked this week fawking around with beefy t00bs and line drawings. Here is how I found my cog | |
01-06-2012, 10:47 AM | #136 |
| Re: helhedded's Comp Shafty OD/UD gears. When moving forward the gearing helps to keep the rig stretched out. So, when you drive it backwards, the exact opposite happens. The front axle is trying to overtake the rear axle by going under the truck (the only direction it can go).
01-06-2012, 07:09 PM | #137 | |
I think the only way for me to answer some basic questions I have about IC is going to be building a few chassis that are almost identical. It seems there is a lot more to be learned when you have these things in your hands than with some other things, like say 1:1 fuel systems and turbos. Anyway, can't wait for more on the rig and some videos so I can see how wonderfully it drives. Last edited by opek; 01-06-2012 at 07:13 PM. Reason: clarity always helps | |
01-06-2012, 08:17 PM | #138 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
01-06-2012, 08:56 PM | #139 |
01-06-2012, 08:59 PM | #140 |
