01-05-2012, 05:22 PM | #21 |
Quarry Creeper Join Date: Nov 2011 Location: Cookeville
| Re: Fastback II build
Well i have ran into a problem my 3 cell lipo will not fit on my front battery tray any sugestions its stock front wheel width not sure if i can mount it in the rear untill i get my mount in the mail i know Duuuuuuuude mounted his in the rear on a custom made plate i might just have to copy him lol.
01-06-2012, 09:35 AM | #22 | |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
| Re: Fastback II build Quote:
01-06-2012, 12:54 PM | #23 | |
01-06-2012, 01:55 PM | #24 |
Looking good, If thats at full lock and its minimal rubbing Id say stuff it an go. Mine rubs the servo and battery slightly turning both ways. Hell Im pretty sure everyone rubs somewhere they dont want it to . You could try to bend it down just a tad or just let it be and see if it hurts anything. Could also fab up some battery and servo armour then you would not have to worry about tires nor rocks.
01-06-2012, 03:12 PM | #25 |
Only thing i forgot to buy was a bec lol heck im not even sure i need one atm till i get the money for a good servo also gonna get some beef tubes when i get the cash. Over all i have enjoyed this build was alot of fun and has turned out sweet the CoG is great on this thing now i just need to get it up and running and finished and get some action pics or maybe a vid, If anyone sees anything that can be improved let me know its my first real build and i hope i did the FB II justice.
01-07-2012, 03:43 PM | #26 |
Well i have ran into yet another problem this time its making my panels my lexon on my motor side keeps braking any suggestions on how to keep it from cracking ? I have cut down my motor plate and also tried heating it and same thing every time went thru 4 panels so far.
01-07-2012, 04:50 PM | #27 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
What lexan are you using? Where is it cracking? Rig looks good, btw |
01-07-2012, 05:08 PM | #28 |
Quarry Creeper Join Date: Dec 2010 Location: Gaffney
I used the face shield from a grinding shield for my panels. easy to cut and haven't cracked one yet.
01-07-2012, 06:40 PM | #29 |
Cracking right where i have to hook the bolts in on the motor side like i said i shaved down the motor plat even and left plenty of extra lexon to make sure it could bend but it just keeps cracking. Got the lexon from the LHS maybe its just a bad batch not sure gonna try to zip tie it this time and not bolt it in.
01-07-2012, 07:11 PM | #30 |
Rock Crawler Join Date: Nov 2009 Location: poteau
hey what driveshaft are you running on the rear? i'm waiting on my fastback chassis and am trying to get parts here before the chassis so i don't have to wait much. i heard the stock ax10 mip shaft would be to short in the rear.
01-07-2012, 08:02 PM | #31 |
I'm assuming you mean under the motor at skid bolts. Try putting a bend there before reaming out the holes. That helped on my T1E shafty.
01-07-2012, 08:22 PM | #32 |
Im running the stock MiP rear drive shaft in the rear it has about a 1/3 of the shaft left with 5 1/6 inch rear lowers so yeah it fits just have to get the dig shaft or cut the longer shaft down for the front. Actually it keep breaking at the motor plate but what i ended up doing was trimming down the bottom and got it fixed ill post pics in a few mins once they upload. |
01-07-2012, 08:41 PM | #33 |
Ok got to Support a couple companys that made this build sick Ok now for just reg pics Anything anyone sees let me know , also for some reason with this new esc my foward and reverse seems glitchy at low crawl speeds its a Br-xl any suggestions on how to fix that would be greatly appreciated. Thank you Rccrawler and all of the members and there great advice. Thanks agian to UGC and HH. |
01-07-2012, 09:01 PM | #34 |
Pebble Pounder Join Date: Aug 2011 Location: dayton.tn
looks great dude..we need to do some ridn soon cant wait to see it thrash |
01-07-2012, 09:09 PM | #35 |
Once i work the bugs out of it im down for that got to get this low speed glitching gone its just kinda like it wants to turn fast but holding back to go slow just jumper than im use to maybe and omg when i turn on the holmes hold brake it makes the most god awful nosies.
01-07-2012, 09:36 PM | #36 |
Might be in need of a BEC. Not the best person on advice but it cured my glitches in my FXR
01-07-2012, 09:52 PM | #37 |
Yeah i was looking at bec when you posted that still not really damn sure how to wire it up but im sure ill figure it out next weekend.
01-07-2012, 10:07 PM | #38 |
With the holmes hold, its not necessary to run it as high as you would with regular drag brake. Try 50% to start. As you increase it the noise will tell you when your to far.
01-07-2012, 10:33 PM | #39 |
| Re: Fastback II build There ya go red wire is positive black wire negative orange wire is signal wire |
01-07-2012, 10:49 PM | #40 |
Sweet i didnt know that about the holmes hold ill have to do that tomorrow and ty for the diagram man ill have to get a bec monday then a servo and a new set of rims and i should be done till tax time then its scaler and moa time lol. |
Fastback II build - Similar Threads | ||||
NorZepol's UGC Fastback II Build | NorZepol | Axial AX-10 Scorpion | 42 | 04-26-2012 10:04 AM |
My AX10 build: Stock to Fastback II | paul6ppca | Axial AX-10 Scorpion | 26 | 09-12-2011 06:44 AM |
brplatz's Fastback II Build | Brplatz | Axial AX-10 Scorpion | 6 | 04-30-2011 02:14 PM |
My Fastback build | JustinThyme | Axial AX-10 Scorpion | 74 | 01-01-2011 05:22 PM |
billj's Fastback build | billj | Axial AX-10 Scorpion | 280 | 11-21-2010 07:13 PM |
