Thread: OKJeepin's 2.2 Sportsman
Old 01-13-2012, 04:11 AM   #1
Default OKJeepin's 2.2 Sportsman
As it is set up 5/13/2012
BWD Wedge
JConcepts "Stage Killah" body
Tekin FXR
Tekin 45t Pro
Futaba R2104GF rx
Futaba 4pl tx
CCBEC
Airtronics 94780M Servo (423 oz/in)
Robitronics 24mm Servo horn
BWD Motor plate
BWD Motor Saver
3Racing Stainless outputs
Losi Boss Claws
Losi gold springs on Alum XR10 shocks w/ 45wt oil
JeepinDoug Cups
VP DH II's and SLW V4's.
Super 300's w/ front locker
J-Fab Designs 8mm Wheel Hex for 300 axles
Beef Tubes in the frony only
Vanquish Knuckles
Axial aluminum clockable chubs
OD/UD gears
87/16 spur and pinion
Gunnar body mounts
3s 800mah LiPo
And a few other things I am forgetting I'm sure!
A pic from when I got it...
OKJeepin is offline   Reply With Quote
Old 01-14-2012, 08:15 PM   #2
Default Re: OKJeepin's AX10
Took it out today and had a blast!
I had a few screws loose (who doesn't around here), but I got that taken care of and had just had an awesome time being amazed at what this thing can do.
One thing I hate is that the front is a 1/16" of an inch narrower than the rear..may have to fix that with some new wheels and hubs in the future!
Old 01-14-2012, 09:56 PM   #3
shoulda took the pic with my inclometer. that pic doesn't do justice to a 55.7 degree dropoff!
hoghead5150 is offline   Reply With Quote
Old 01-14-2012, 10:06 PM   #4
Holmes Hobbies
CD13's Avatar
Looks real good, I like the chassis and link setup real well, Looks like a very capable rig.
CD13 is offline   Reply With Quote
Old 01-15-2012, 12:33 PM   #5
Thanks man, pretty proud of it!
Had a little carnage today, just ordered a new case.
Old 01-15-2012, 05:00 PM   #6
AHHH a dab of super glue should fix that right up
Rig looks good man, love the body
xjcritter is offline   Reply With Quote
Old 01-15-2012, 05:25 PM   #7
Holmes Hobbies
CD13's Avatar
I would be getting ahold of airtrionics, I bet they replace that.
Old 01-15-2012, 07:41 PM   #8
nice ride, looks familiar. i have had two of those airtronics servo cases fail, time for a hitec. by the way i think i have a spare top from the last one that died.
joshsmith512 is offline   Reply With Quote
Old 01-15-2012, 08:57 PM   #9
I am going to try and fix this one I guess, and if it fails again...I am going with a Hitech for sure.
Old 01-15-2012, 11:44 PM   #10
aaaahhhh, i bet it'll buff out!
Old 01-16-2012, 12:30 AM   #11
I'm really thinking about ditching the Warthog frame my truck came with and doing a chassis like this... Seems like it's a lot lighter and would have a much lower CoG.
bcbsox is offline   Reply With Quote
Old 01-16-2012, 06:49 AM   #12
The rig looks familiar. Did you build it from the kit or did you get it from a guy in TN?
Good looking rig
Harvo is offline   Reply With Quote
Old 01-16-2012, 07:19 AM   #13
Good looking rig
It started its life in Tennessee, went to Oregon, now it resides in Oklahoma!
Greencrawler here on the forum built it I believe.
Old 01-21-2012, 10:50 AM   #14
I finally got my Links set up, took some doing and a lot of playing around but I am good to go now! Ended up front uppers mounted in the bottom hole, and the rears in the middle, and it is working great right now!
Got my new servo front in the other day, and put this CI servo guard I had on...hopefully it will hold it together now!
By the way, I super glued the one that broke back together, and it held together until this one came in, crazy, never thought it would work!
Also added some Axial lockouts.
Got the front tires done for now. Put in some custom foams, and cleaned off all the inside lugs on the Rovers.
Also added a little protection for my motor, don't know if I REALLY needed it but...
Old 01-21-2012, 11:03 AM   #15
HAAAAA I was only joking when I suggested super gluing it back on...Who would of thought it would of really worked. Thats funny right there I tell you what
Old 01-21-2012, 02:19 PM   #16
Looks great man hope you have as much fun with it as I did.
Glad you finally got the links fixed.. If you have any questions on how or why I did something feel free to ask
greencrawler is offline   Reply With Quote
Old 01-21-2012, 02:34 PM   #17
Thanks, I have had it apart so many times, I know it like the back of my hand now!
Old 01-21-2012, 02:35 PM   #18
Don't ever underestimate super glue and redneck engineering!!
Old 01-21-2012, 06:50 PM   #19
i will testify that the super glue held. he glued it and about 2 hours later we had it out in the rock garden. took some good hits, and he got it in a few binds that when he turned it would flip the truck back and forth. i was amazed!!
Old 01-22-2012, 06:06 PM   #20
I might need to locktight them three screws next time...
Good as new!
Did a lot of tuning today, moving the front shocks, and front links around. I believe I got 'er tuned to my driving style!
OKJeepin's 2.2 Sportsman - Similar Threads
OKJeepin's RedCat OKJeepin Redcat Crawlers 15 01-03-2012 09:50 AM
Axial Scorpion AX10 Axle Give-A-Way **Free AX10 Axles*** Rockpiledriver Axial AX-10 Scorpion 297 08-27-2007 06:15 AM
