Recycle your Gatekeeper GC3a Chassis I first saw this idea on Ben's build, see link. http://www.rccrawler.com/forum/axial...id-2012-a.html I normally run an XR10 body on the gatekeeper, seems to work for me -but now I want all my rigs to run bodyless. http://www.centrolinfedema.com/dalla...s/IMG_2040.jpg This is a hybrid between a BWD SSS-R Bodyless Topper and a stock Gate Keeper GC3a. http://www.centrolinfedema.com/dalla...s/IMG_2504.jpg http://www.centrolinfedema.com/dalla...s/IMG_2505.jpg http://www.centrolinfedema.com/dalla...s/IMG_2506.jpg The Gatekeeper is already built like a tank, with the SSR-R top I could take some material and a few chassis braces out, but I'm going to start my testing as is first. Note: This is not a 100% perfect fit, you will need to tug on the delrin plate a little to get everything to fit. Also, you will need to relocate the battery if you strap it over the steering servo like I normally do. http://www.centrolinfedema.com/dalla...s/IMG_2517.jpg In the pictures (2) delrin 1/4" rod's are used , but the one's included in the SSS-R bodyless kit fit w/o issues. http://www.centrolinfedema.com/dalla...s/IMG_2519.jpg I still have not tested it, looks "cool" but the truth is in when I test it at our Feb Comp meet. I noticed that the the top of the windshield support that will act as the pivot point when you are upside-down is close to the front of the chassis. This means that there is less levarage for the front weight to work against = May not be a great performer when you are upside down. This will have to be determined through on the job training... http://www.centrolinfedema.com/dalla...s/IMG_2518.jpg I need to install a new front servo battery plate, the front of the frame hit the back of the battery ( Not shown in the pictures) This is the picture of another gate keeper that now has been converted over to a Fast Back II Chassis. This is what the front end needs to look like if you are going to try out the SSS-R topper http://www.centrolinfedema.com/dalla...s/IMG_2206.jpg |
Re: Recycle your Gatekeeper GC3a Chassis I like that. I was thinkin a few days ago that i wish there was a cool topper for the gatekeeper |
Re: Recycle your Gatekeeper GC3a Chassis Looks good Eric, thanks for the mention:). the BWD topper has the look of a VW in shape but on its own it looks cool but being adventrous with panels you can change it and make it almost a fastback in stlye like i did. ive found that as the topper reflects a VW if your a bit adventrous i think you could make it look good with any chassis with some imagination as it sits low it looks good with the big crawler tyres. I look foward to see where you go with this, Ben |
