01-17-2012, 03:11 PM | #1 |
Newbie Join Date: Nov 2005 Location: loudon
| ax10 rtr vs rtc
is there a diffrence between rtr and rtc ? would one be better than the other for the sportsman class 2.2 for me and my 8 year old son ?
01-17-2012, 03:23 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
| Re: ax10 rtr vs rtc
here ya go. AX10 Scorpion RTC (PT#AX90011) : 4WD, Electric, R/C Rock Crawler AX10 Scorpion RTR (PT# AX90002) : R/C Rock Crawler/Rock Racer honestly the RTC would be better for actual crawling in my opinion. The RTR is geared more towards backyard bashing style. They are basically the same truck with a few different things between them. Someone else might be able to chime in with the exact differences, but I went with the RTC version and loved it till the last time I checked my bank account |
01-17-2012, 04:46 PM | #3 |
Newbie Join Date: Feb 2009 Location: Cumming
| Re: ax10 rtr vs rtc
RTC: 55T motor, slower but more torque, battery life will last a little longer Pro-line Hammer tires, great for rock crawling Longer wheelbase, lower to ground, better suited for crawling RTR: 27T motor, faster but not as much torque, battery life will be a little shorter Rock Lizard tires, not so great for rock crawling but a good bashing tire Shorter wheelbase, higher off the ground, better suited for bashing |
01-17-2012, 05:33 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: Canada
| Re: ax10 rtr vs rtc
I've never really thought the RTR had a home.. The stampede 4X4 is a better choice, WAY more durable and just a better basher. but nothing traxxas has ever dreamed of can come close to the RTC.
01-23-2012, 11:51 AM | #5 |
Newbie Join Date: Jan 2012 Location: east
| Re: ax10 rtr vs rtc
I am thinking of buying a ax10. I like the idea of of the RTR, but I can't find a new one. What would have to be changed to make the RTC run like the RTR? Sorry, New to Crawlers Thanks |
01-23-2012, 12:21 PM | #6 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: ax10 rtr vs rtc
not sure of the difference between the RTR and RTC but i bought the RTC and love it, did a few easy free mods and it climbed well right out of the box. i've thrown a couple hundred bucks at it now and its awesome. a friend has the old ARTR and has done lots of mods. the RTC has the new 2.4ghz and one thing i found out yesterday about it is i put in a hitec 7955TG and the stock AE-2 esc did not like it, it couldnt keep the volts up if your working the steering lots and driving at the same time, the esc would shut itself off, then you gotta turn off the rig wait a couple seconds then turn it back on and its fine but it will keep doing it. so im going to toss in my novak rooster crawler because i know they work with the 7955 and can handle the volts. so if your planning on running a high torque servo be prepared to either run a BEC or upgrade the ESC. apparently the RTC has beefed up plastic links, im running them still with no problems but plan on an aluminum link kit soon. i ran the hammers but they are small in diameter, i have just recently got a set of sedona's and love them, now that im not running my hammers i might do a sipe job or something on them. |
01-23-2012, 01:09 PM | #7 |
| Re: ax10 rtr vs rtc Don't waste your money. Find a vendor here that sells either delrin or titanium links. The aluminum is good until it starts getting scratched up...after that they tend to grab instead of slide. Delrin or ti will stay slick forever.
01-23-2012, 01:18 PM | #8 |
| Re: ax10 rtr vs rtc
i dont care if they get scratched up and start to grab im sure my 7955TG servo and sedona's will pull me through it!!! i'd rather it be sticky because its more predictable and doesnt slide around too much and i can make the ass end go where i want it easier. plus im going for the route that my friends have so if i fawk up a link they have spares and i can toss a new one on and good to go.
01-23-2012, 01:24 PM | #9 | |
| Re: ax10 rtr vs rtc Quote:
But I doubt you'll ever, ever break a delrin or ti link. A rod end maybe, but not a whole link. As far as powering through a rough spot...that is not always as easy and predictable as you'd think... | |
01-26-2012, 10:42 AM | #10 | ||
Quarry Creeper Join Date: Nov 2011 Location: Kentucky
ax10 rtr vs rtc - Similar Threads | ||||
RTR or RTC? | mww24 | Axial AX-10 Scorpion | 10 | 10-07-2011 10:04 PM |
Another which one to get thread - RTR vs. RTC | mpkelley20 | Newbie General | 15 | 08-30-2010 11:50 AM |
