11-25-2010, 04:37 AM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: Ukraine
| UA Fastback build
So, here is my thread and i'm going to tell u what i do and listen to all ur suggestions and comments. I did some RC before. I used to have a nitro monster and that was fun. But i never suspected i would love so much the crawlers So, around 3 weeks ago i got this babe So smart, so mint, so sweeet Before i get the rig, yeah, i spent a lot of time reading and still reading So, the first thing i did were the breathable wheels, syped the tires and the NIMH battery which i moved and ziptied it in the front below the batt. plate. That give me a bit more fun, then stock, but not too much. I was really disappointed it couldn't climb the stairs. Those were too slip and the rig was hanging on his belly. Nevertheless, I decided to take it for a short walk outside the city jungle and that was the first time crawl Don't have pics in action, but it was so fun, that i wanted more and more. That was the moment i've started to think too much. The more i did the more i was unsatisfied with results Anyways, I bought a new 10kg servo, installed an aluminium steer link, but then downgraded to stock, coz it probably could damage the knuckles, and Axial BTA on the way. The thing makes me extremely mad . Once u turn the servo, the only one wheel is turning and the link bends in a funny way. As soon as all RC resources/shops are outside of the hole i live in, i have to deal with what i have, so, here's what i have. AX10 chassis. Body. I trimmed the rear and a bit the front, but then.... I've found UGC. Every day was looking and drooling on that fastback dreaming to order one in winter, but alias :( Understanding that u can't go stock with FB i decided to make a small dedication to Juan's chassis. Yeah, it is not the same, it looks different but it reminds me a lot of FB and i still dreaming that some day i will get it. Didn't have chance to test it outside yet, but hope this weekend will set everything clear. the wait distribution. I'm still trying to find out the ballance and it is a bit hard. I have 105 grams in each front wheel + servo + 150grams batts + 90 grams on bats + 60 grams on servo, so, totally around 510grams (sorry guys, we don't use OZ here) In the back i have the big batt pack, which is 300 grams. And now, i am stuck. Probably, i have to move the big batty inside a bit to make the rear wheels lighter, or to add the weight directly to wheels and move the batty somewhere else, that would definitely change the situation.... i hope. Links and susp. Here, i did a few things change coz: We have no spares here I've ordered new alu skid plate, high clearence links for the rear and just regular but delrin for the front. I stay with stock leaking shocks muhaha. Don't care at least for now. I 've added some spacers in front to make the travel less, made the rear sprigs stiffer, as u can see from the picture, and did the same to the right front one which leaks. I still have this torque issue, i've already mirrored the trany, but nothing helps :( we have the front wheel in the air mostly and i still trying to fight those damn angles As u can see, the last one sucks. And at the uphil the right front wheel wanna take out and make the whole rig fly down Any help and comments will be appreciated a lot Thnx Last edited by shizzz; 01-28-2011 at 06:40 AM. |
11-25-2010, 05:45 AM | #2 | |
Rock Crawler Join Date: Feb 2010 Location: chin ckeck
11-25-2010, 10:40 AM | #3 |
Pebble Pounder Join Date: Jun 2010 Location: Farmington
So the batterys on the front axle are just for weight, or are you running batterys on both axles?
11-25-2010, 01:19 PM | #4 |
I keep them also charged, but they r only 1400 mah (it's a kinda safety exit, just to last play time a bit more), so that is around 40 mins or even less if it is cold outside. The big batt i will probably reassemble and move instead of thy in front after i get BTA. I'm not sure i wanna go lipo - that will tear out some bucks from my pocket. am not greedy, just not sure. the capacity is much less then the one el cheapo batt i use, all that maintenance issues as well. |
11-25-2010, 02:38 PM | #5 |
Quarry Creeper Join Date: Oct 2010 Location: So. Cal
I see a row of Felt MTB's back there Nice truck, keep it up. |
11-25-2010, 02:55 PM | #6 |
Thnx I used to sell Felt, but since i'm official distributor of Commencal i sell Commencal bikes + a lot of dj and street stuff and yet state of art Intense cycles |
11-25-2010, 03:05 PM | #7 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
drive shaft angle u need to make the rear drive shaft as straight as poss if not it will cause the twist your fighting . i my self never worried about getting it all out just get it under control where u can drive it start with the rear drive shaft angle an i mite run a lil preload in the left rear to keep it down
11-25-2010, 03:19 PM | #8 |
It is as straight as it was when i got the truck. The stock settings. I think this is the straightest one. As for the preload, i also did it, as seen from the pic, but it does help just a bit. lil bit confused |
11-25-2010, 03:59 PM | #9 |
ok is the rear 4 linked an dont worry about where it was stock make it as straight as poss now stock it twisted relly bas as well so dont go by that just make it straight now that is where most of the twist comes from
11-25-2010, 04:07 PM | #10 | |
Sorry, wasn't trying to derail your thread. | |
11-25-2010, 04:12 PM | #11 |
Nevermind, this site is about passion |
12-02-2010, 11:05 AM | #12 |
12-02-2010, 11:20 AM | #13 |
For more thread derailment... Where in Ukraine are you? My wife was born in Kiev |
12-02-2010, 11:42 AM | #14 |
Thnx a lot Juan Derailing the thread, i am exactly at the place, where ur wife was born haha, may be the same district even |
12-02-2010, 11:54 AM | #15 |
She is from Vinogradar
12-02-2010, 12:18 PM | #16 |
12-02-2010, 12:22 PM | #17 |
12-02-2010, 12:44 PM | #18 |
Vinogradar is an opposite side of Kiev, but i have a friend who used to live there and i'm familiar with the place - used to ride my enduro bike in the woods nearby I wish Kiev had so many places to crawl u have there guys As for the straight line of the shaft - yeah, i know already it will rip off if the angle is set wrong and it affects the twist somehow. Thnx for that Last edited by shizzz; 12-02-2010 at 12:47 PM. |
12-02-2010, 12:51 PM | #19 |
I forgot to add that your take on the ugc fastback looks great! I feel your pain about very few rocks. I live in Florida, plenty of swamp, very little rock. The building my wife grew up in is the last apartment building before the woods. Her room view was of the woods Last edited by DickyT; 12-02-2010 at 12:54 PM. |
12-02-2010, 12:59 PM | #20 |
How did u meet her? That's another side of the planet |
