is it worth trying to make an ax10 faster? Looking at buying an ax10 but have heard they are really slow. would it be worth even trying to make it faster so i dont hafta carry it from obstacle to obstacle or should i be looking for something else? |
Re: is it worth trying to make an ax10 faster? You might want a Wraith then |
Re: is it worth trying to make an ax10 faster? what do you plan to use it for? the ax10 can be made plenty fast but won't crawl as well"thumbsup" |
Re: is it worth trying to make an ax10 faster? Im running a 55 turn motor and 3cell lipo and I think its plenty fast and will still crawl |
Re: is it worth trying to make an ax10 faster? Quote:
Axial AX-10 Rockcrawler to Rockracer. - YouTube now fitted with a 8.5t brushless motor.. http://i591.photobucket.com/albums/s...h48/001-11.jpg http://i591.photobucket.com/albums/s...h48/002-10.jpg Sean .. |
Re: is it worth trying to make an ax10 faster? The AX-10 is absolutely a great GO FAST rig! Check out Bender's original AX-10 video! Pretty much stock with 3S lipo... Axial's RTR AX10 - YouTube The Original AX-10 had an open front diff, stiffer springs, 20t pinion, and 27t motor. It was set up more as a rock racer, while the kit was more crawler oriented...! |
Re: is it worth trying to make an ax10 faster? The standard esc can handle a 19 turn motor these can be had for under $20, also for $10 you can get a set of pinions 15 - 25 tooth (20t will give you good speed over standard). These two mods will greatly increase your speed and cost you less than $30. Problem is once you have all this speed everything on the ax10 is plastic junk and will break, then you have the fun task of replacing all these plastic parts with alloy. |
Re: is it worth trying to make an ax10 faster? Ax10 is a very versitile truck (in my opinion) I love mine, I have different set ups for example when I wanna bash around and have fun with my son I run a 20t motor and 21 tooth pinoin. But when I want to do some serious crawling ill run a 55t with 14 tooth. So it can be very fast or as slow as u can make it. Great truck to buy |
Best ESC to get is the Traxxas XL5 it's water proof 12t 550 titan motor or 15t 540 motor , Li-Po / Ni-Mh compatible . Has 3 running modes Trainer mode for crawling, Bash/race mode for the speed... . |
3s lipo and 35t handwound - great for crawling with wheel speed when you want it |
Re: is it worth trying to make an ax10 faster? well they are ''slow'' i guess you can say but most are faster then you can walk any way so its not like your going to be waiting for it if you drove as you walked. And theres always the summit trans, i have that in my scx10 not sure if any one tried to fit it in a ax10 yet."thumbsup" |
The thread tital is ... is it worth trying to make an ax10 faster? Not how to make it crawl beter, Some people wanna go down the road of a RockRacer , then others go full blown FOFF "thumbsup" which is all about speed not crawling8).... .. |
Re: is it worth trying to make an ax10 faster? the faster u go the more money u spend how deep is your wallet |
Re: is it worth trying to make an ax10 faster? 1 Attachment(s) They don't handle as well as a Wraith but they are fun to drive fast. I have one with a 17t motor and 3s lipo with 5.5 inch tall TSL swampers. It is to high to corner very good but goes like hell up hills.:flipoff: |
