Thread: Need Pictures - Broken Driveshafts..
Old 02-02-2012, 01:51 PM   #1
Default Need Pictures - Broken Driveshafts..
Like the subject says - I need some pics of your broken, busted, or twisted driveshafts.
The better the details, the better the pic, the better.
I am working on a design of some super strong shafts, and am wondering how they are breaking. I know the common problem is the setscrews coming loose and causing havoc, or them not coming out because they are rusted in place. Stainless steel fixes that problem, but I need to know if the shafts fail in the tubes, at the universals, or some place else?
Post up links or pics please.
Thank you everyone..
bigstu is offline   Reply With Quote
Old 02-02-2012, 03:03 PM   #2
Default Re: Need Pictures - Broken Driveshafts..
Is there any need for other strong options? The Junfac, Mips en Punnisher shafts seem to do the job just fine!
crawl rookie is offline   Reply With Quote
Old 02-02-2012, 03:13 PM   #3
TSK
Shelf queen
TSK's Avatar
If you are talking plastic driveshafts, they just break at the yoke ears, or the male splines twist and won;t allow for the telescoping.
As far as options available to replace them... there's plenty already available.
TSK is offline   Reply With Quote
Old 02-02-2012, 03:41 PM   #4
Punishers don't last long in a 12+lb TTC rig, on a brushless motor with 3s power.
I am working on something that will be high $$$ and BOMB PROOF. High alloy, high strength stainless steel. Maybe even have needle bearings in the yokes..
Like you would dig these out of the wreckage at Hiroshima and put them in your truck, bomb proof..
Just to give you an idea, the company I am working with, makes shafts for medical grade equipment and for the U.S. Military... nuff said..
CVD's are VERY nice, but don't give the angles that these trucks some times need. The plastic shafts always seem to fail as scorpionking described..
I guess I should have asked for anyone that runs punishers or other all metal drive shafts for their carnage pics.
And guys, if the carnage is the pinion gear all tore up, please include that.
Old 02-02-2012, 03:46 PM   #5
You won't break revo driveshafts.... Allways used them in my superclass rigs!
Old 02-02-2012, 03:51 PM   #6
Don't think Revo shafts will fit, which ones you talking about? The diff to wheel shafts?
Part number would be awesome.
Old 02-02-2012, 06:08 PM   #7
TSK
Shelf queen
TSK's Avatar
SUPER SHAFTS! My overkill tech contribution
AND
8mm Outputs
Need Pictures - Broken Driveshafts.. - Similar Threads
broken, just not sure what??? MudboyNJ Newbie General 11 09-16-2011 04:11 AM
Broken Gears/blown bearings - Pictures R2theICKY Axial XR10 28 09-15-2010 02:01 PM
Car Show Pictures (With pictures of 3 Full Size Scorpions!!) 56k WARNING Krawlin Chit Chat 21 11-13-2007 06:16 PM
