03-02-2012, 06:04 AM | #61 | ||
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
| Re: TC's "Old School" Sportsman Build Quote:
03-02-2012, 06:11 AM | #62 |
| Re: TC's "Old School" Sportsman Build |
03-02-2012, 06:13 AM | #63 |
Another small update, there was a lot of talk in the XR section about knuckle weights vs. wheel weights and the pros and cons of each. After getting my comp truck back in one piece, I put the knuckles back on that truck and installed the DH's on this truck. Where there was not difference really on my XR, this truck REALLY woke up. I'm glad I didn't drop the money on the new knuckles for this truck because I'm going to run wheel weights. I think because there is less weight on the front axle, and more suspended, this truck really seemed to be able throw things around. It greatly reduced my turning radius.
03-02-2012, 06:16 AM | #64 |
| Re: TC's "Old School" Sportsman Build true, but I talking about the rear tires on, not only this truck, but the comp truck. I saw a little of this in Lafayette with the original protos. Shell can speak to this, the truck just could not get through the gate without wasting the time forcing an xr where only a berg should go! (PS, it survived and scraped through beautifully.)
03-02-2012, 06:28 AM | #65 |
03-04-2012, 10:28 PM | #66 |
| Re: TC's "Old School" Sportsman Build After a less that stelar debut performance, torque twist abound, I've done a few mods to greatly reduce its affects. For the rear, I spaced the uppers at the axle. For shocks, I've gone to big bores on all four corners. Drivers rear has a rear mini T blue spring and passenger rear as a green. I didn't have a heavy enough spring for the losi shocks so I swapped them out. I'd rather run these anyways. These springs seem to keep the rear planted much better. Also, you can see I mirrored the transmission. To save a little sprung weight, I made a small tray out of 1mm delrin and put the receiver and ESC off the front axle. Lost some weight with the BWD electronic's tray. I tried Maroon springs, but they seemed too heavy so I'm running Pinks up front. I Also spaced the front uppers at the axle a little bit. It looks like I may have bent the screws holding the front upper link mounts on. Last edited by TC09mini; 03-04-2012 at 10:30 PM. |
03-05-2012, 04:42 AM | #67 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
I see you have both your front and rear axles clocked way up. I know its for clearance, but a smart guy from texas told me once to run my pinion angle flat. I thought he was just trying to F with me, but i tried it anyway. It completely got rid of all torque twist. Now, i dont know if there was some geometry setup involved or what, but since then i have set all my shaft rigs with flat pinions and torque twist hasnt been an issue since. Its a definite trade off, but well worth it in my opinion.....try it.
03-10-2012, 01:06 PM | #68 |
Rock Stacker Join Date: Jan 2011 Location: Carencro
great build TC!! Couple of questions for you. 1) what width hubs are you running on the wheels to get out to 10-5/16? 2) The trans. being mirrored puts the spur gear to the back? 3) Are you running stock length XR axles or did you cut them down? 4) Do the longer beefy toobs have splines for the chubs or does the screw just hold them on? I always thought mirrored put the spur gear to the front I'm finally going to get mine all put together (or shell is really, THANKS!) and I thought my trans. was already mirrored. If it's not i'd like to just get that out the way. |
03-10-2012, 06:40 PM | #69 | ||
2. Yes, its out back so that the motor weight is more forward on the passenger. Having the weight on that side helps combat torque twist. 3. Stock length, no mods at all. 4. Just screw in with a health amount of lock tight. Hope this helps. Last edited by TC09mini; 03-10-2012 at 06:43 PM. | ||
03-10-2012, 07:02 PM | #70 |
| Re: TC's "Old School" Sportsman Build Cool. Keep the updates coming. I'm curious to find out if you have the same results that I did.
04-25-2012, 01:40 PM | #71 |
| Re: TC's "Old School" Sportsman Build This truck is going up for sale. After ECC, I'm closing up shop for a little while. |
TC's "Old School" Sportsman Build - Similar Threads | ||||
TC's CDW Chump RT build/re-build | TC09mini | Axial XR10 | 250 | 09-14-2012 12:42 PM |
BuckImod's Sportsman Rebuild! | BuckImod | Axial AX-10 Scorpion | 78 | 08-25-2012 04:37 PM |
TC's GC-3A Build | TC09mini | Axial AX-10 Scorpion | 111 | 06-16-2011 10:55 PM |
fred0000's sportsman build | fred0000 | Axial AX-10 Scorpion | 118 | 05-13-2011 11:29 PM |
My first sportsman build | adamargue | HPI Wheely King | 45 | 04-13-2011 07:21 AM |
