02-05-2012, 04:20 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Roanoke, Va
| Drive way too fast question and front locker question.
I bought my 1st Ax10 from ebay and it was an RTC type. Stock everything to the body. It drives too fast. When I mean it drives too fast, I mean it will do a 3 wheelie and makes it hard for me to crawl anything. I was wondering what does the Ax10 RTC comes stock as far as gearing and motor type? Is there any way I can slower it down some. Just enough to be able to crawl. I don't know if this is stock but my rear axles are locked and my front axles are not, they are open diff. Please let me know if that is how they come. I want to lock the front. It crawl badly with open front diff. What do I need to get my front axle to be locked? What do I need to do or get to slower down my speed? |
02-05-2012, 04:51 PM | #2 |
| Re: Drive way too fast question and front locker question.
I'm sorry, its an RTR after I did some research. What do I need to do to convert it to a RTC? 55T axial motor and set of cross looking steel axial lockers should do me fine, correct? Last edited by Mr.JayDeeM; 02-05-2012 at 05:01 PM. |
02-05-2012, 05:32 PM | #3 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
that will slow you down. My RTR came with a 27 turn motor and open front diff. The "maltese cross" locker is axials heavyduty locker.
02-05-2012, 05:37 PM | #4 |
Is there another suggestion for slowing down? I'm new to this whole building myself thing. I've been using my buddy crawler to test out on before buying and ended up liking it. His was slow but not too slow. So, 55t axial motor and the set of maltese cross locker will do it. Should I go ahead put the cross in the rear as well? What kind of grase should I use for the diffs? |
02-05-2012, 05:38 PM | #5 |
RCC Addict Join Date: Oct 2007 Location: gervais
| Those two will do fine, what do you plan on doing? There are multiple ways you can set it up, If it's just for bashing/ light crawling those will do just fine
02-05-2012, 05:45 PM | #6 | |
| Re: Drive way too fast question and front locker question. Quote:
I want to strictly crawling. I want to be able to climb rocks and what not. Also I notice my suspension set up is a little way to stiff. | |
02-05-2012, 05:57 PM | #7 |
Is 35t reasonable?
02-05-2012, 07:35 PM | #8 |
35 turn will work well. Axial has springs alot softer than RTR springs. Axials site has them listed by color coding. Usingn softer springs will definately help to soften up your suspension. I believe i used their softest springs on the fron and second softest on the rear. Also, better tires will make a world of differance. Rovers or sedonas seem to be the big names right now.
02-05-2012, 08:45 PM | #9 |
Now, I gotta decide which motor to go. I never experience either turn motors. 55t or 35t. i will check my local hobby shop to see if they carry any axial springs and what not.
02-06-2012, 01:10 AM | #10 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
Just try using a smaller pinion on the motor. 12t with a 27 would crawl nicely. Pinons are cheap. Get new springs or cut a couple rings off them. Heating them up (dull red work from middle out to ends) will soften them as well. Then just spray plastidip on them to cover the metal. |
02-06-2012, 10:22 AM | #11 |
| Re: Drive way too fast question and front locker question. |
02-06-2012, 05:39 PM | #12 | |
Won't I loose ride height if I cut a coil off? I don't see how it will make the spring softer. This could be a cheap mod until I get new springs.. I'm not sure what battery it is. It belongs to a buddy of mine, he letting me borrowing it until then. How would I lower the voltage? | |
02-06-2012, 07:27 PM | #13 | |
Quarry Creeper Join Date: Aug 2011 Location: not south enough
8.4V is 7 cells 9.6V is 8 cells I ran a 27T motor and 18T pinion to crawl with a 8 cell 9.6V. You prob have a 6 or 7 cell, you will be fine once you drop your pinion size and get softer shocks. slow crawling is fun, but wheelspeed can help too, finding a happy medium will work great. | |
02-06-2012, 07:45 PM | #14 | |
I did some mods today after work. I took apart my front axle to lock the axles. I took it apart and clean off all the grease good, then I used SEM quick set 50 glue to fill in my carrier and wait about 3 mins then it was hard enough to install it back together. Voila, got me a free home brew locker for the front. Then I took all my wheels off and drill one hole on the back side of the wheel to let air out. It made an world of a difference. Tires are soft enough. They will do for now until then. The stiff springs still sorta hold it back. I'm thinking about adding weights in each wheel to see how much it helps before considering spring work. | |
02-07-2012, 02:40 AM | #15 |
Newbie Join Date: Sep 2011 Location: Australia
In stock form the ax10's are not great crawlers, the previous owner has probably changed the gearing to give it some momentum to get up obstacles it could not crawl. Maybe just get the front locker and see how it goes from there...
02-07-2012, 09:19 AM | #16 |
My buddy rig is 55t, 14 pinion and 87 spur.
Drive way too fast question and front locker question. - Similar Threads | ||||
creeper locker question | twacrawler | Venom Creeper | 11 | 05-05-2011 07:49 PM |
Diff Locker Question | DezertCrawler | Axial AX-10 Scorpion | 2 | 04-18-2011 11:04 PM |
mrc locker question | joshlg06 | Losi Mini-Rock Crawler | 5 | 04-17-2011 12:17 AM |
Question on Diff Locker | EvoChaos | Axial SCX-10 | 5 | 03-22-2011 03:34 PM |
AX-10 axle locker question | the02stangman | Axial AX-10 Scorpion | 10 | 12-24-2009 09:57 AM |
