02-08-2012, 01:25 PM | #1 |
Rock Stacker Join Date: Nov 2011 Location: Birmingham, Alabama
| od/ud
Hi guys, pretty new to crawling 1/10 scale. been doing 1:1 for quite a while. Can you guys tell me where you are getting your od/ud setups at? Does it matter which axle i ud/od? thanks much, Donnie |
02-08-2012, 01:30 PM | #2 |
| Re: od/ud
As soon as they are released, they sell out. I've bought them from RPP Hobby, Phill's Hobbyshop, TCS, Stormer Hobbies, A Main Hobbies... anywhere. And yes, you have to OD the front, UD the rear. And you can run whatever combo you want as long as the front is moving faster then the back. |
02-08-2012, 02:22 PM | #3 |
| Re: od/ud
TCS has them...better act fast since they do sell quickly sometimes: Axial Racing Optional Ratio Gear Set 36/14 for Axial AX10 Scorpion #AX30401*-*Driveline Parts: Axles and axle parts*-*-By Truck: Axial AX10 Scorpion, SCX10, Honcho*-*The Crawlers Store LLC Axial Racing Optional Ratio Gear Set 43/13 for Axial AX10 Scorpion #AX30402*-*Driveline Parts: Axles and axle parts*-*-By Truck: Axial AX10 Scorpion, SCX10, Honcho*-*The Crawlers Store LLC |
02-08-2012, 03:39 PM | #4 |
| Re: od/ud Quote: |
02-08-2012, 03:46 PM | #5 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: od/ud
I beleive so.
02-08-2012, 04:05 PM | #6 |
| Re: od/ud
Are those the newer ones at TCS? I guess I will roll the dice.
02-08-2012, 04:09 PM | #7 |
Rock Crawler Join Date: Mar 2009 Location: houston
| Re: od/ud |
02-08-2012, 06:56 PM | #8 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: od/ud
I bought some from TCS last month, and it is the one with the hole in it.
02-08-2012, 06:58 PM | #9 |
| Re: od/ud |
02-09-2012, 09:59 AM | #10 |
Quarry Creeper Join Date: Apr 2008 Location: SHADYSIDE
| Re: od/ud
I just installed mine I did the od in the front only,rear is stock gears,with clocked axle hubs an cvds I cant believe the turning radius now, wow!cant wait to get outside on some rocks an see how it climbs now,the semi ok turning radius is now excellent! Ive been reading all the threads about od an ud gear changes an the results you guys talked about.very happy should of done this when i bought my ax10 the first time. next is beef tubes,lol |
02-09-2012, 01:41 PM | #11 |
| Re: od/ud
thasnks much guys, ordered some today!
