02-13-2012, 08:14 PM | #21 |
Quarry Creeper Join Date: Nov 2011 Location: Cookeville
| Re: Strong CVD's
lol nope just saying i have never heard the terms interchanged in the south but we are all pretty simple we dont over complicate things and naw no wiki needed for this a axle is a axle and a drive shaft is a drive shaft for all simple purposes. even in front wheel drives carrs that have no drive shafts persay we still call half shaft axles or cvs but i understand what your saying. Since rc shaftys are more like a true 4x4 drive shafts are drive shafts and axle shafts are axle shafts and in a moa its more like a cv axle/drive shafts kinda like a front wheel drive car. |
02-14-2012, 02:39 PM | #22 | ||
Quarry Creeper Join Date: Nov 2011 Location: Kentucky
| Re: Strong CVD's Quote:
02-14-2012, 05:38 PM | #23 |
Newbie Join Date: Feb 2011 Location: ooltewah
| Re: Strong CVD's
The (cv) is referring to the type of joint. Axle shafts and drive shafts can have cv joints or u-joints. Also 1:1s their are some 4x4s with solid differentials that have cv's or a type of cv like toyota's. They have birfields and they look just like 300s. The only difference is rc cvs(300) have a pin, and the 1:1s have balls, a cage and star.
02-14-2012, 05:54 PM | #24 |
Quarry Creeper Join Date: Sep 2007 Location: strawtown
| Re: Strong CVD's
hopefully we have that out of the way now and we can get back to finding out what's the strongest outside of sds300s for our purpose |
02-14-2012, 06:47 PM | #25 |
Rock Crawler Join Date: Jul 2010 Location: St. Albans
| Re: Strong CVD's
I am tired of breaking Mip cvd's and also Axial cvd's. How many people have shortened xr10 universals to work in axial axles? Are they any stronger?
02-14-2012, 06:50 PM | #26 |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
| Re: Strong CVD's Dude got everything answered about CVDriveshaftaxlesandwhanots...without needing to search. Next time he has a question he'll get flamed by the same mugs for not searching... This is how a well oiled machine works, take note. |
02-14-2012, 06:53 PM | #27 |
| Re: Strong CVD's Couple guys have them in their scalers, Emaxx motors on 3 and 4s and they stay together from what I've seen so far.
02-16-2012, 07:09 AM | #28 |
Rock Crawler Join Date: Aug 2010 Location: Socal
| Re: Strong CVD's
With my experience if you are not going to go to 300's or XR10 axle shafts then stay with the stock dogbones. They are by far stronger than any of the other CVD's. |
02-21-2012, 09:29 AM | #29 | |
First off i did a search and read numerous threads on the subject. But like 2006shelby said earlier we in the south are simple and like things cut and dry. After reading the other threads I was still just as confused as i was before. maybe its me maybe its not. either way when you try to post an answer to a question try and remember that statistically humans don't retain anything written above a 5th grade level and that lawyer documents, as confusing as they are, are technically written at a 12th grade level. Simplify your answers as much as possible and stop making it sound like your ("your" is used in context as a general term) smarter than you(again in general) really are. | |
02-21-2012, 10:23 AM | #30 |
| Re: Strong CVD's |
02-21-2012, 05:58 PM | #31 |
| Re: Strong CVD's
The xr 10 universals are rather strong from what i can tell.
02-21-2012, 06:42 PM | #32 |
Rock Crawler Join Date: Jun 2009 Location: summertown
I run 1st design RC4WD XVD's. Been going strong for two years now. I ran them in my comp rig for a year and they were put in my scale truck in November 2010. I've never run Axial CVD's, but the MIP CVD's are junk. |
02-22-2012, 04:56 AM | #33 |
| Re: Strong CVD's |
02-22-2012, 05:19 AM | #34 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: Strong CVD's If you run long beef tubes, they don't require modifying. If you run Standard tubes, you need to shorten each 11mm(ircc) and regrind the locker flats. Its not very hard, can be done with a hand saw and file. Obviously, you also need to change to xr10 chubs and knuckles. |
02-22-2012, 08:00 AM | #35 | |
04-14-2012, 06:50 AM | #36 | |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
whre can i find those 300?and another alternative for 300? Last edited by Kitty; 04-14-2012 at 06:55 AM. | |
Strong CVD's - Similar Threads | ||||
servo doesn't seem as strong as it should | mckenzies | Electronics | 9 | 06-03-2010 10:57 AM |
motor not strong enough. | slvrf150fx4 | Newbie General | 6 | 05-20-2007 03:27 PM |
how strong | partylikarockstar | Newbie General | 4 | 11-25-2006 02:35 PM |
