02-20-2012, 01:36 AM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: SLc,UT
| Fastblack2 UGC
I have had this FB2 for months and it is my sons. He did not want to change from his F-4/fastback hybrid. Finally convinced we begin. Swapping over everything over to this chassis. Going to place the electronics in a better way this time and droop the front shocks. If that sucks we will change it. Seems like that will help fight the TT the most. There are a couple climbs the other chassis would not do that my XR will. I think the drooped front will get it. If not we will keep working it. Running a 16t HH crawl master with a 12 tooth pinion. Going to put a 90 tooth spur with the 12t pinion just to see. It is plenty fast with the 12/87 set up Still going to run the Vp dig. He likes fighting it out at comps, sometimes he is the only shafty out there. He thinks it cool and usually beats a handful or more MOA rigs every comp. Usually is key word but never last. put in some threaded brass inserts in the trans mounting holes.. great idea BTW this will be cleaned up |
02-20-2012, 01:40 AM | #2 |
| Re: Fastblack2 UGC
Still need to make front upper links. The rears are a litte longer than normal. Torque twist sucks and I want to beat it down... The front uppers are going to be shorter than I thought. Hopefully not to short. |
10-19-2014, 02:59 PM | #3 |
Rock Stacker Join Date: Oct 2014 Location: La Porte
| Re: Fastblack2 UGC
Can you show a close up of where you mounted all the electronics? I'm doing a similar build with my daughter and I'm still pretty newbish lol.
10-19-2014, 10:03 PM | #4 |
| Re: Fastblack2 UGC
O.G. D-mount? Do I see Razors on there too? Same wheels I got on my Poison Dart. Pretty shnazzy. Last edited by Trubble; 10-19-2014 at 10:05 PM. Reason: Upon further review...... |
Fastblack2 UGC - Similar Threads | ||||
got the goods from UGC | bozo | Axial XR10 | 22 | 03-07-2011 11:23 AM |
