03-13-2012, 07:01 PM | #21 | |
| Re: What is Torque Twist (TT) and how to fix it. Quote:
03-13-2012, 07:04 PM | #22 |
It's the axle pinion gear trying to climb the ring gear.
03-13-2012, 07:07 PM | #23 |
| Re: What is Torque Twist (TT) and how to fix it. |
03-13-2012, 07:09 PM | #24 | |
Rock Crawler Join Date: Jun 2011 Location: San Diego
03-13-2012, 07:10 PM | #25 |
| Re: What is Torque Twist (TT) and how to fix it. I'm gonna have to agree! It has to do with the resistance to movement, which gear ratio plays a part in! The twist as we see it is 100% a result of the drive shaft. The bike example still has torque twist, but it's ***looks*** like a low antisquat value.
03-13-2012, 07:13 PM | #26 |
03-13-2012, 07:14 PM | #27 |
03-13-2012, 07:18 PM | #28 |
14,196 worthless posts.
03-13-2012, 07:19 PM | #29 |
14,198
03-13-2012, 07:22 PM | #30 |
Am I the only one who sees the counter rotation unit as a valid option? If the two drive shafts spin in opposite rotation of each other, the TT they produce should cancel each other out. The only adverse affect I can foresee is that the main chassis will either lift or squat down, but not pitch or roll. If a thermonuclear rocket scientist like EGRESSor can make one, I'm sure a drunk left turn veering hillbilly like Duuuuuuuude can make one work. And I agree with Duuuuuuuude on the whole transverse mounted motor thing. The TT develops between the output and pinion gear. The axle representing the vise on the bench, and the output representing the drill in your gorilla grip. Last edited by TSK; 03-13-2012 at 11:17 PM. Reason: Spell checked for those without imagination. |
03-13-2012, 07:33 PM | #31 |
03-13-2012, 07:40 PM | #32 | ||
Quote: C'mon Lassie! What are you trying to say? Did Timmy fall down the well? | ||
03-13-2012, 07:43 PM | #33 | |
WTF is a "Fran drew mounted motor thing"? | |
03-13-2012, 07:48 PM | #34 |
Pebble Pounder Join Date: Sep 2011 Location: USA
03-13-2012, 07:48 PM | #35 |
I guess the question is: what ever became of Egressors counter-rotating thingy?
03-13-2012, 07:49 PM | #36 | |
Hahaha. Trah. I don't proof read: Meant "transverse mounted" And I guess auto correct doesn't work too well. I'll edit that post when I'm not on my phone. | |
03-13-2012, 07:50 PM | #37 |
WTF is a "Fran drew mounted motor thing"?[/QUOTE] X2 I need to know what it is too. It made me laugh when I read it. Sent from my iPhone using Tapatalk |
03-13-2012, 07:51 PM | #38 |
03-13-2012, 08:02 PM | #39 |
| Re: What is Torque Twist (TT) and how to fix it. It's a permalink to a specific post in this thread which addresses that issue. |
03-13-2012, 08:13 PM | #40 | |
Are we talking about chain drive? I thought Manning summed up the side effects pretty well on that one... Or are we talking about CIII's counter rotational thing? | |
What is Torque Twist (TT) and how to fix it. - Similar Threads | ||||
Help me understand, explain, and fix or solve torque twist | opek | General Crawlers | 85 | 02-22-2012 06:45 PM |
torque twist... | 73fordhighboy | Axial AX-10 Scorpion | 10 | 01-11-2010 11:46 PM |
torque twist | renzo | Newbie General | 8 | 08-09-2009 07:47 PM |
Torque twist | Greatscott | Axial AX-10 Scorpion | 1 | 04-01-2009 09:23 PM |
Torque Twist? | Mini | Newbie General | 3 | 12-13-2008 10:19 PM |
