02-22-2012, 06:06 AM | #1 |
Pebble Pounder Join Date: Jan 2012 Location: vincennes
| need help picking next upgrade
My current setup is gatekeeper gc-3a chassis mamba max esc 35t warrior motor white dot rovers losi gold springs on stock rtr shocks(had to throw in spacers for it to fit) cs-170 servo with cc bec everything else is stock drive shafts knuckles chubs shocks receiver transmitter all gears steering linkage what do you guys think i should upgrade next. im thinking overdriving the front, upgraded steering linkage, knuckles and chubs. any opinions |
02-22-2012, 06:39 AM | #2 |
Newbie Join Date: Dec 2011 Location: Dandridge
| Re: need help picking next upgrade
drive shafts are a must |
02-22-2012, 07:36 AM | #3 |
Pebble Pounder Join Date: Feb 2011 Location: Burnaby, BC
I would opt to upgrade Chubs, knuckles and steering linkage next, and consider BTA to get your steering out of the way.
02-22-2012, 08:50 AM | #4 |
You will soon be snapping the Chubs and knuckles. They are some of the weakest parts on the front axle.
02-22-2012, 10:32 AM | #5 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i havent broke anything yet but im running the alum knuckles, still need c-hubs though.. i'd stick with the knuckles, c-hubs, definitely get an aluminum steering links, overdrive the front.. you can get away the stock driveshafts, both my friends run MIP's but there not needed unless you keep twisting the stock ones. what kind of radio/reciever are you running?? |
02-22-2012, 11:59 AM | #6 |
Right now just the stock ar-1 and transmitter Sent from my i777 using Tapatalk. |
02-22-2012, 12:52 PM | #7 |
ok that'll work.. just was curious because if your still using the shitty AM radio crap then i'd add that upgrade to the list as well but since your not your good there. |
02-22-2012, 12:59 PM | #8 |
well its got that giant ass metal antenna that you have to extend before you get any decent range. and i dont know how well bta works with the gatekeeper. i havent seen it done
02-22-2012, 04:11 PM | #9 |
Rock Stacker Join Date: Jan 2007 Location: On the rocks
behind the axle steering doesnt work with the gate keeper,I would do the od/ud and chubs as for drive shafts use these TRA1953 1953 Long Truck 1/2 Shaft Pro Pak (6) - Traxxas Cars/Trucks I have yet to break one of these on 3s with a 35t handwound and for $10 you get 5 spares I was twisting stock axial ones everytime out!!
02-23-2012, 12:40 PM | #10 |
can anyone recommend some knuckles. im getting the axial clockable c's but not sure on the knuckles. i want to go with the high steer ones but then my tires will be eating my shocks. they already hit them when the steering is locked one way and flexed
02-23-2012, 02:13 PM | #11 |
Rock Crawler Join Date: Nov 2009 Location: poteau
go with the hi steer knuckles anyway, just turn down the epa's till your tires clear.
02-23-2012, 03:36 PM | #12 |
| Re: need help picking next upgrade |
02-23-2012, 06:44 PM | #13 |
Newbie Join Date: Apr 2011 Location: Grass Valley
Stands for End Point Adjustments its probably a little dial on your remote that says st.d/r next to it basically it adjusts the throw of your servo left to right. sorry not too sure about the ae1 transmitter configuration, I have the next gen ae2.
02-23-2012, 07:04 PM | #14 |
Oh yeah I've got that on mine Sent from my i777 using Tapatalk. |
02-24-2012, 11:46 PM | #15 |
Wait no I don't. I can just adjust center Sent from my i777 using Tapatalk. |
02-25-2012, 04:40 AM | #16 | |
Pebble Pounder Join Date: Jul 2010 Location: malta
| Re: need help picking next upgrade Quote:
02-25-2012, 06:02 AM | #17 | |
Anywhere in the us I can get them? Don't want to wait 2 weeks Sent from my i777 using Tapatalk. | |
02-25-2012, 09:07 AM | #18 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
need help picking next upgrade - Similar Threads | ||||
Help on picking chassis.. | 93-306 | Losi Mini-Rock Crawler | 12 | 02-04-2010 01:55 PM |
picking battery | sivad | Duratrax Cliff Climber | 6 | 03-19-2009 08:55 PM |
Help picking a battery | xjman | Chit Chat | 6 | 09-18-2007 05:50 PM |
picking out a new Servo | jardiniboy | Electronics | 19 | 12-05-2005 02:46 PM |
