RCCrawler Forums
RCCrawler Forums (http://www.rccrawler.com/forum/)
-   Axial AX-10 Scorpion (http://www.rccrawler.com/forum/axial-ax-10-scorpion/)
-   -   my ax10 swx sporty rig (http://www.rccrawler.com/forum/axial-ax-10-scorpion/377375-my-ax10-swx-sporty-rig.html)
peterk 04-09-2012 07:37 PM
http://s1155.photobucket.com/albums/p548/peterk10/
here are the pics of my rig i have custom made 4 link in the rear sill am running a partial stock 3 link in the front.
steering i am using a hitech hs-5645mg servo and custom alum steering arms
tires im running stock proline hammers with xr10 wheels
the motor i have in it im not shure what it is exactly
my esc is a axial ae-2 out of a wraith
for batteries im running a 2 cell 1300 mah lipo
peterk 04-09-2012 07:40 PM
Re: my ax10 swx sporty rig
http://[IMG]http://i1155.photobucket...ckcrawl009.jpg[/IMG]
http://i1155.photobucket.com/albums/...ckcrawl008.jpg
http://i1155.photobucket.com/albums/...ckcrawl007.jpg
http://i1155.photobucket.com/albums/...ckcrawl006.jpg
http://i1155.photobucket.com/albums/...ckcrawl005.jpg
http://i1155.photobucket.com/albums/...ckcrawl004.jpg
http://i1155.photobucket.com/albums/...ckcrawl003.jpg
peterk 04-11-2012 12:42 AM
Update I got rid of the junk stock tires I'm now running hb sedonas
obebaldone1 04-11-2012 02:43 AM
Looks like you have a fun rig. The sedonas will be a big up grade.
peterk 04-11-2012 09:11 AM
yes i just need to find a good foam setup that works good with them i was thing crawler innovations double douces
AX10wannabe 04-11-2012 09:55 AM
foams i think depends on the weight of the rig. my ax10 (stock chassis for now but working on a modified SWX version with homemade skidplate) is about 5.5lbs and im running the sedona's with 7oz in each front wheel and 4oz in each rear wheel and it climbs pretty good. i got stock uncut foams too. you want the tire to wrinkle a bit when its spinning looking for something to grab on to going up a climb.
the good thing about the crawler innovations foams is that you can play with it and tune it easier. i have no experience with these foams but have heard some good things about them.
have you tossed your rig on a scale yet? also if you can swap your driveshafts end for end and put the female end on the axle this will save your D-shafts from getting twisted on the rocks.
peterk 04-11-2012 10:12 AM
roughly its 5lbs but not sure ill weigh it when i go to the crawl space today and i will be swicthing my driveshafts around later today thanks
peterk 05-10-2012 08:22 PM
Wei broke a chub just playing around in my front yard now I'm going to do the xr10 mod
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
