04-13-2012, 01:36 PM | #1 |
| What Next?
Well I can't seem to get my rig to perform the way I want it to. Turning is obviously the biggest issue my tires rub on my Losi springs and even when I put a little dab of CA to hold it in place it still falls off. I'm thinking about getting a new chassis that allows me to inboard the front shocks so I can do the XR mod. I'm currently running the VP Incision Pro chassis for a good 2 seasons now and no matter what I do I can't seem to dial it in. Also 95% of our guys are MOA. I'm more into scale but comp crawling with them in our sportsman class is still fun. I've narrowed down my chassis choices to 3: 1. BWD's Wedge Low Pro w/Rat Rod topper bodiless...not sure if this will be legal? AX-10 Wedge Low Pro - Black 2. UGC's Fastback II in black UGC Store 3. T1e's new AX10 Sportsman chassis Ax10 Sportsman Chassis All around $100 and all are delrin which is a plus. This time around I'm trying to build a lightweight rig that doesn't just hammer through courses. Which chassis would be best through yall's experiences? |
04-13-2012, 02:21 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: What Next?
The T1E and FB are both great chassis. If your going to do the xr full width conversion dont worry about inboarding shocks. Between the added width and castor you can dial in, you should be able to get great steering and have your shocks where they should be with minimal rubbing. |
04-13-2012, 03:43 PM | #3 |
Rock Stacker Join Date: Apr 2009 Location: sheilock
| Re: What Next?
what you need to do is stop crying over your lil spring and keep working at what your got...i was in your shoes 2 years ago now look im still runing the same chassis different link set up tires still rub up against my springs and face it my sportsman can hang with my buddys moa! |
04-13-2012, 05:26 PM | #4 | |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: What Next? Quote:
my stock springs rub with my sedona's... oh welll... give er' a little more throttle if i had to choose i'd say #2 or #3. | |
04-13-2012, 05:28 PM | #5 | |
Quarry Creeper Join Date: Jan 2012 Location: okanagan BC
what he said......im running the bender sw3, old, but still rips it up just fine, im running dh with 335 hubs, i inboarded the shocks and outboarded the links, they rub a bit .........but I have pulled some lines that modded xr's couldn't follow i say work out the chassis you have, | |
04-13-2012, 11:07 PM | #6 |
| Re: What Next?
btw im rockin a modded bender swx...but if i had to choose from your 3 chassis...it have to be #3 t1e! |
04-14-2012, 12:50 AM | #7 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: What Next?
i recomend FB II,all the way,i have one and looks awesome |
