05-07-2012, 11:29 AM | #1 |
Newbie Join Date: May 2012 Location: Crawfordsville
| Will ax-10 driveshafts connect to a summit transmission?
Hello, I am new to the forum, I am wanting to build a scale crawler, and I like the idea of the high/low transmission from the traxxas summit for slow crawling and higher speeds every now and then. I am wanting to use axial ax-10 axles and driveshafts along with the summit tranny. My question is, will the ax-10 driveshafts connect to the summit transmission? Thanks!
05-07-2012, 11:34 AM | #2 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
| Re: Will ax-10 driveshafts connect to a summit transmission?
Yes and no. You will need to adapt the driveshafts to the summit outputs, since they are larger. There are many options out there so check around. I went with larger revo shafts and reduced the end going to the axle. You could also make a metal adaptor, if you have metal working skills. Wes |
05-07-2012, 11:47 AM | #3 |
Thanks Wes! It sounds like a good idea to go with revo shafts and adaptors. Thanks again
Will ax-10 driveshafts connect to a summit transmission? - Similar Threads | ||||
Ax-10 driveshafts with traxxas summit transmission? | Chevycrawler627 | Newbie General | 2 | 05-24-2012 10:09 PM |
transmission problem with driveshafts | mysterygamer | Axial AX-10 Scorpion | 15 | 01-03-2010 07:56 PM |
